![]() | Home > Maintenance & Modifications > Door Corrosion - how quick is too quick? |
Since the Puma in 2007 for sure (maybe earlier but not sure about that) all Defender side doors are steel only, no more alloy was used at all. Don't think any Puma doors, unless vehicle has been entirely neglected and abused, should be rusting at all. My 2008 built doors show zero rust, so a 2011 surely should be like that too.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
alfajock Member Since: 12 Jan 2011 Location: Bedfordshire Posts: 227 ![]() ![]() ![]() |
That's useful information, thanks very much
![]() CLS 350 CDI for the sensible stuff |
just in proses of re spaying driver door having the same problem bubbling up with bi-metallic corrosion, door is about 4 year old to, but not genuine new LR door so i don't think i make much odds
all steel doors way to go |
My 2006 TD5 van were fitted with the new, all steel doors from the factory.Sounds like you were lied to.Forgfive mi grammar!! Pov.spec,ftw. 2006, 110,TD5.
