![]() | Home > Maintenance & Modifications > Loose Trim in rear of utility |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5062 ![]() ![]() ![]() |
Its not riveted.
Go and pull it off (if its the rear) and you will see. Mike |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Those aren't rivets - they don't fix to anything.
Just give it a tug and it'll come off. It's held in place by 2 spring clips. You'll need to bend them slightly with a pair of plyers once you've taken it off and then it'll just push back in place. It'll never be tight so I drilled the flange behind it (about 2/3 up the leading edge - with the fake rivets on) and put in a captive nut or rivnut. That way I can really secure it in place. If you have windows, you can get Mantec window guards and they recommend the approach above to provide some level of security. I did the same for the speaker panel below since it was held in place by those stupid plastic expanding rawl plugs, which broke the first time I was fiddling around. Now everything is nicely bolted in place with some easy to remove and re-fit rivnuts ![]() I'll take some photos when I'm back in the UK One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
