![]() | Home > Off Topic > MOT Changes in 2011 Heads Up |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
HID lights – Specifically those aftermarket kits that give the very bright headlight beams. Any cars found with these kits will be an automatic MOT failure. Testers are able to easily spot the difference between HID kits, and manufacturer fitted Xenon’s. Easy to spot as Xenon cars have suspension level sensors, in car beam adjuster, and usually headlight washers.
Chipped ECU’s - Unsure of just how/if this one will realistically be enforced, but any cars with chipped ECU’s will in theory be an MOT failure. I can only assume VOSA have found an easy way of checking ECU software through the cars OBD port (diagnostic plug). Wiring harness – The general condition of he wiring harness will be checked to make sure there is no rubbing or chaffing, and that the harnesses are in generally good condition. If unsecure, or damaged again MOT failure. Airbag warning lights - If any warning lights are illuminated, it will again be an MOT failure. The above was confirmed in the October 2010 VOSA newsletter. Which can be viewed as a PDF from their website. Link below, see page 8 for details. http://www.dft.gov.uk/vosa/repository/MoT%...202010.pdf Pom edit: link fixed Last edited by pom on 8th Jan 2011 8:36pm. Edited 1 time in total |
Link don't work ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Would be good to hear from Pete Bell on the chipping thing? He will know how they plan on seeing if they are chipped and what can be done about it.
Pete. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1812 ![]() ![]() ![]() |
Page 9 points to incompatability of bulbs/light units & illeagle chipping of engines as something for future thought - have I missed the article?
