Home > My Defender > 300tdi 110 Project.
Page 3 of 6 <123456>
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Tks Andy......I have a nice xs steering wheel to go on it too Thumbs Up
Post #513436 12th Mar 2016 7:53am
Christian1402
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Indus Silver
Nice progress, I'm guessing with you painting the front of the chassis, that you've decided to repair it and not replace?
Post #513486 12th Mar 2016 11:57am
Nidge
Well Things are now a lot clearer in my head after the long weekend......but my credit card is going to have to take a beating !!
I decided (had no choice in the end ) to order a New Richards Chassis.
To help me finally make a decision on the chassis, I removed the rear tub and got busy with the 9" angle grinder.
First impressions weren't too bad but the more I cut away the worse it got, so new chassis it will have to be.
Plan to have a go at replacing it myself, now that the long evenings are upon us Smile
On the positive side the Rear Tub is in good shape with just a bit of flaking paint, power hosed it down and ready for a good coating of Dinitrol or similar , haven't decided on what to coat the underside with yet. Seat belt brackets taken off and coat in Por15 to help seal against corrosion.
Removed the cappings too as they are gone in the corners and waiting on my friend Nick to send me on a replacement
set Whistle
Now to get on with breaking down all the panels and removing the engine and box in prep for the new chassis arrival in May......Kind of excited now Rolling with laughter
Post #518487 28th Mar 2016 6:08pm
L110CDL
Good decision about the new chassis, lot of weight off your mind now and you can look forward with great excitement Thumbs Up Clayton.
Keeper.
Post #518562 28th Mar 2016 8:30pm
Cupboard
Are you keeping the hydraulics?
Post #518646 28th Mar 2016 10:26pm
Nidge
Nope...sold on the winch and bumper
Post #518908 29th Mar 2016 5:54pm
Nidge
With the new chassis due in early May, I set about making preparations to switch over the chassis.
As I already had the rear tub off, I'm going to try to lift the front section of the body in one. Plan to make up a gantry crane and lift it by the bulkhead chassis mountings and roll the chassis out.
I made up a temp support in wood to keep the cab and roof section intact.
Apart from the Brake lines, Hopefully everything else is now disconnected and ready for lift off !!
Next weeks job is to make up the gantry crane for the lift.......
Post #522548 9th Apr 2016 7:00pm
Nidge
And we have lift off....came apart without too much stress in the end, after I realized I forgot to remove the 2 little M6 bolts at the front of the seat box Embarassed
Plan is to clean and paint up the underside of the seat box in POR15.
Give engine and gear box a good clean and fit a new clutch and rear crank seal when access is so good...Anything else I should do before swapping over to the new chassis.
Post #527414 27th Apr 2016 9:33pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Awesome considering it seems to be all outside work. Looking forward to seeing how you progress Thumbs Up
Post #527427 27th Apr 2016 10:05pm
Nidge
A bit of an update for anyone who's still watching Very Happy
removed engine and gearbox and now down to the rolling chassis. New one arrives next week, Trevor Cuthbert very kindly put it on top of his load that he's collecting from Richards.
Changed the rear crank seal with a genuine LR one and sent the flywheel to be skimmed as it had a few marks in it. HAve new Borg and Beck clutch kit with heavy duty fork to be fitted on build up. It's amazing now easy it is to access the clutch with no body in the way !!
Next update will hopefully have a shiny new chassis Very Happy
Post #529630 6th May 2016 10:04pm
grumpy old git
Great work! Thumbs Up
Post #529687 7th May 2016 10:10am
Timo
Canada 1984 Defender 110 300 Tdi SW Alveston Red
Well done. Nice seeing a good rebuild. Keep the photos coming
Tim Series II in pieces
1984 Defender 110 (3.5l V8 now 300TDI)
Post #529935 8th May 2016 1:24pm
L110CDL
I'm still watching and will be to the end Nidge, great update Thumbs Up Clayton.
Keeper.
Post #530303 9th May 2016 10:38pm
Nidge
Well look what landed here in Kildare yesterday. My Brother kindly collected the chassis for me, it fits straight in to the hugh load bed of the lwb volkswagon crafter, a monster of a van !!
First impression of the Richards Chassis is that its very well put together but a tad rough around the edges but maybe I'm just fussy !!
There are no holes for the brake pipe clips or fuel lines, so probably means drilling the top to take some small P clips Crying or Very sad
Post #531619 15th May 2016 7:35am
Nidge
The weather gods were shining on me, a full day of sunshine in Ireland and no rain.....so I cracked on with assembling the rolling chassis.
Had most of the brackets, bolts etc. ready to go, all cleaned up and replaced where necessary. Painted in 2 coats of Por 15.
Not a bad days work Whistle
Post #531620 15th May 2016 7:46am
