- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Puma (Tdci) > Why do starter / ignition switch die and what can be done? |
HardCharger
Why do starter / ignition switch die and what can be done? | |
Hi All!
Looks like my third starter / ignition switch is starting to act up, I was told that maybe there was something causing it to heat up and warp since the innards are mostly plastic.
Is there a way to prevent this from happening prematurely? Are there electrical gremlins that are having a field day with me?
My indie Rover tech is trying to see if the starter / ignition switch from a Ford Ranger can be good substitute as it is seems better built than ours. Same can be said of the main light switch and the indicator assembly.
Thoughts, tips, and suggestions?
23rd Mar 2016 6:08am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
