Home > Td5 > REPLACE TD5 FRONT DISCS |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
In theory, if there is no play in the bearings before removal, there will be no play when refitting
The ABS ring is held on with 5x 10mm nuts accessed between the hub and disc. With this removed, it allows access to the disc retaining bolts, as per normal |
27th Mar 2016 9:04am |
Mudlark46 Member Since: 27 Mar 2016 Location: Yorkshire Posts: 8 |
Thanks for that, hope it's as simple as it sounds. will the ABS ring only go back in the correct position or does it need marking before removing ?
27th Mar 2016 10:27am |
Forgive me if I am wrong as it's a couple of years ago since I changed my front discs but the Defender abs is read from the hub under the swivel pin therefore no ring on the back of the disc whereas a Disco II has the ring on the back of the disc.
27th Mar 2016 10:47am |
Indeed. Rear discs have the ring behind the discs, front discs are read off the CV joint
Teach me not to read the post properly Disco 2 is read from inside the hub assy Last edited by Disco_Mikey on 27th Mar 2016 10:57am. Edited 1 time in total |
27th Mar 2016 10:56am |
Thanks for that I will investigate. I did realise that the Disco hub is non-serviceable and the 110 is serviceable. My old press-release 1983 110 didn't have things like ABS, so all a bit new to me, never had a problem with any of these bits even though I've had this TD5 110 for 11yrs
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
You'll be fine. You don't need to touch any ABS components on a disc change.
27th Mar 2016 11:00am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
This/\/\/\
Front ABS is read off the shaft not the hub, as is the rear.However removing the drive member can be a REAL pita!! Pov.spec,ftw. 2006, 110,TD5. |
29th Mar 2016 12:06pm |
