Home > Technical > Discovery td5 autobox
landyman37
Hi all. Am looking at fitting a autobox out of a discovery v8 into our defender td5 manual at the moment I have the complete disco to remove all the items am looking at pros and cons on fitting it will it be straight forward or a nightmare. Has anyone done this converstion?
Thanks for reading
Phil
Post #518054 26th Mar 2016 9:59pm
The auto is the same as the td5 disco auto box, though I'd 'guess' you'll need the td5 bellhousing.
Post #518063 26th Mar 2016 10:33pm
landyman37
How about electrics ?
Post #518065 26th Mar 2016 10:45pm
I'm not sure on the td5, I only use the reverse light wire from my auto. Not fussed about the inhibitor, that's just a nanny.
Post #518080 26th Mar 2016 11:59pm
landyman37
Ok I will keep you all posted on how it goes
Post #518882 29th Mar 2016 4:45pm
mikeh501
if its out of a Disco1 then it will be a ZF4HP22 which doesnt have any electronics to worry about. If its out of a Disco2 then it will be the ZF4HP22EH which is the one which requires an ECU. You can get one from Ashcroft called the compushift for about a grand.
Post #519022 29th Mar 2016 8:39pm
landyman37
It's a discovery 2 gearbox. Think I am going to have a try with the discovery ecu first see if I can get it to control it.
Post #519153 30th Mar 2016 9:38am
mikeh501
good luck Smile
Post #519167 30th Mar 2016 10:53am
jst
if its not a manual box you wont get it to work without compushift, for one thing a def doenst have the pitch and yaw sensors that the box ecu looks for.
for non e box you will need to find a way to accelerator feed to box. alot revert to cable actuation just for the box.
note V8 TC is prob not ideal size for the td5. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #519246 30th Mar 2016 4:52pm
landyman37
Can I not put all the electrics off the discovery into the defender?
Post #519493 31st Mar 2016 9:45am
jst
you can try, many have before including various companies, i dont know of any that have made it work that way. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #519502 31st Mar 2016 10:21am
