![]() | Home > Maintenance & Modifications > Routing power cables from the battery box to the front bumpe |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
out of the battery box underneath , plenty of cable ties keeping it away from anything that moves or is hot basically
There are some spare grommet holes in the battery box, cut a slit in the grommets then pass the cable through travel along the top of the chassis, tied down with big cable ties. You will need to protect the cables in a couple of places (split plastic tube) where they pass over the mountings on the chassis. tie wrap them along the front of the lower grill. Original Member Pie n Pea Club.
110 HCPU Tipper |
KarlB Member Since: 08 Feb 2010 Location: Canberra Posts: 91 ![]() ![]() ![]() |
Some jumper points out of the front of the battery box is another option you may like to consider:
![]() Has workrd well for me, jump-starting others and connecting my portable air compressor. Cheers KarlB ![]() |
