![]() | Home > Puma (Tdci) > Puma oil filter housing damage |
Take it back and tell them to sort it FOC
jlprojects Member Since: 10 Dec 2010 Location: now in Ireland Posts: 48 ![]() ![]() ![]() |
Hi AndrewS,
Tried even threatened to dump it on there doorstep. I've spent the last 10 days trying to sort this out with the Polish dealer, UK dealer and Land Rover. I'm glad I'm not in the UK as the UK dealer would not be standing now, I've never heard so much C***p in my life from a dealer. John |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1833 ![]() ![]() ![]() |
Has someone chiselled that off thinking its a conventional cannister type filter? There appears to be no damage to the hex nut, whoever serviced it last needs to replace it pronto - can't be too much cost can it? Is a transit one the same?
No, the dealer serviced the puma before I drove to Poland. I was in the centre of Lodz when the red light came on, about 10 seconds later the engine made a few knocking sounds and it's now scrap. Land Rover Assist are shipping it back to the UK. I've spoken to the Polish dealer and the UK dealer and Land Rover UK and it seems it is not covered by warranty.
Well scrap may be to strog a word, the Polish dealer said they tried to turn over the engine and when I went to look at it it had the damaged filter still on and the MIL light was still on. I do not think they tried very hard. When it gets back to the UK my brother is going to change the oil housing cover and filter, replace oil and reset MIL light. See what happens then. John |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
That is a catastrophic failure and therefore should be covered by warranty.
Glyn ![]() |
Contact Land Rover Customer Care. Explain what has happened calmly and dont shout, explain how disappointed you are and perhaps mention that you were looking at replacing the vehicle with a new one etc etc. Tell them who the dealer was that carried out the service. They should kick the dealers ass and you should get a new engine FOC. 130's have feeling's as well you know
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Wont that depend if Land Rover say it was damaged buy one of their workshops refitting it or by something flicking up off the road/track and causing the damage in which case its a insurance job? And if it was the Workshop fitting it then surely the dealer is liable not land rover? Pete. |
Zinke,
Totally agree, I continue to discuss with the dealer who is doing his best to move the issue to Land Rover. When the issue is 1. Did or was the damage the result of a technician over-tightening the unit, or 2. A component failure. I have had several discussions ranging from the dealer telling me that I was off road at the time and damaged it. Also that I hit a pavement, not sure about that one. Also that something hit the cover and damaged it. Looking at the cover I see no scratches or indeed no impact damage. Also looking at pictures in my gallery the land rover has not ever been off road or even green laned, having been owned by my brother before me. I have owned the land rover for about 3 weeks and I'm thinking of naming it "Chucky". John |
One point I do need to mention is that the Polish dealer told me he would carry out the repair under warranty. The Polish dealer then discussed with the UK dealer, who said no. I spoke to the UK dealer service manager who told me he had informed land rover UK that it was not possible that the damage was caused by his technician as he had overtighened a unit and it did not crack. As I told the UK service manager, it was not a comparable test, how can he even think to compare a test done in a workshop environment with my land rover that I drove to poland. Does anyone on the forum know how the material reacts in different conditions, is it possible to overtighten and then crack later, engine vibration temperature etc. I would still like to resolve this wit hthe dealer, if not my only course of action is through the courts or perhaps my NFU insurance via a claim. John
Whats the cover made of? I assume its plastic as all the ones on other engines ive seen are.
If there is no impact marks on it (hard to see from the pics but looks ok to me) then the only way it can be damaged is the dealer over tightened it. Ask the dealer to find out what it was tightened with and if he says anything other than a torque wrench then youve got him over a barrel! A crack like that looks to me like they put it back on with a impact gun! Pete. |
It's made of plastic, the dealer said it was torqued to 25.5 Nm as per the manual, never expected any other answer really. John
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2456 ![]() ![]() ![]() |
By looking at the crack shape (the way it is strained) seems to me the failure started when some chap tried to remove the cover.
Stupid question: is that hex shape to place the wrench? or maybe they used the other sort of clamp tool (whatever the name is). Anyway, you should get a new engine FOC. Puma 110" SW ............................................................. Earth first. Other planets later |
another careful dealer who check there work
![]() 1968 1/32 scale Britains 109 Pick up. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5078 ![]() ![]() ![]() |
That is as mentioned a catastrophic failure and a written off engine.
What you are into now, is split into a debate on 2 things: (and we will assume its a loss of oil as i bet it is) 1) Did something occur that caused the filter housing to fail 2) Did the dealer servicing it damage it and thereforecause the failure. Well in 1 this is simple, regardless of off road or not (as they will honour the warranty FACT) then its a warranty claim and any dealer can sort it. if its 2 then it ISNT a warranty claim - its a DEALER claim and this becomes an ARSE as ive been there. Eventually if you talk the right language Land Rover will help - but this is primarily a dealer fault and the claim is there. Now as much as you wont like this and as much as it is the dealer (and their incompetence) there is a case that you need to make sure you dont make you liable by NOT checking the work - you are responsbile for that and they could get out of the claim if you didnt take action to minimse the damage. But for me it would see 2, dealer did a ![]() Good luck...i sense a few days battle coming on. Mike |
