![]() | Home > Maintenance & Modifications > TD5 Slide Hammer |
I must admit that it's years since I used a slide hammer and then only on some large farm bodgenering. I know that LR have a slide hammer set up to remove the Td5 injectors but after doing the job a few times now I'd still be wary of using a slider that was a universal one as there's not a lot of purchase room under the injector and I prefer to be able to "feel" that the pry bar/long allen key is in the right place before any pressure is applied. With the solonoid and delicate electrickery gubbins on the side of the injector I could see a tearful outcome if you get things wrong.
The LR slider is fab just works, makes the job silly simple. As a matter of course I now change the seals every 18 months or so and the slider is a highly valued part of my tool kit.
If you plan to keep the TD5 just invest in the tool it will pay you back in time. |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 ![]() ![]() ![]() |
Hi Guy, any idea of the part number / price? 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
Hi Landybear. I bought mine from Dingo croft. They are relatively expensive at �120 but it is a tool for life and does make the job super easy. Like I said previously I consider the o-rings and washers to be service items and replace them semi regularly so the tool gets used and travels with me on long trips in the tool kit. It breaks down to quite a small volume and easily stored in the service box.
http://www.dingocroft.co.uk/acatalog/Engine_Tools2-p2.html ![]() Click image to enlarge |
Thats great many thanks. I like to have the correct tools for the job rather than just making do as from experience something either gets damaged or it takes 10 times as long to do whilst trying to find something to use.
Paul 2003 Defender TD5 Hardtop (current - work in progress) 2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
I agree completely. When you come to do the job this is a good guide;
http://www.discovery2.co.uk/Injector%20Seals.html And replace the injector loom at the same time. |
