Home > In Car Electronics > Pioneer MVH-X560BT only working with ignition ON...
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
The HU will not come on without the ignition being in position I or II?
The factory fitted HU would come on for 1 hour at a time and this was working 5 minutes before changing the HU.
I checked the LR wiring, the PURPLE wire is PERMANENT LIVE & ORANGE/WHITE wire is IGNITION LIVE (could have this wrong?)
On the HU, YELLOW wire is PERMANENT LIVE & RED wire is IGNITION LIVE
On the supplied ISO adapter, this is how the wires connect.
The pioneer manual says that the red & yellow wires may need to be swapped.
I tried swapping them, still no operation with the ignition off???
Big Cry Big Cry Big Cry
Could this have something to do with the 'radio code'?
Hoping someone out there has fitted this same HU or has had the same issues and a simple solution will solve it...
Thanks in advance
Other than that, this HU is near the top of my list of upgrades. Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #514796 16th Mar 2016 8:12am
dorsetsmith
most radio have switch feed to power it up and permanent feed to maintain memory i.e. time set up and station programming
Post #514813 16th Mar 2016 9:11am
Bushpig
Yep, Mr. Smith
That is the exact wiring diagram I checked before opening up the console.
There were 4 wires on the LR side:
Black = Earth
Orange/White = Ignition Live
Purple = Permanent Live
??? = ??? (Just went to check what it was & now cannot get HU surround off, to get it out to check)
But it was 0 volts with ignition off & did not check it with ignition on, yesterday during install.
The HU is holding all user settings and radio tuned frequencies...
Currently it is connected:
HU - LR
Yellow - Purple
Red - Orange/White
Black - Black
Blue/White - ??? (but this is the wired remote, which I don't have & will never use)
& if I swap the Yellow & Red on the ISO adapter, it does not hold the settings, just as though the battery has been disconnected.
So do believe that I've got the wiring right Question
But no HU with ignition off...
Big Cry Big Cry Big Cry Big Cry Big Cry Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #514821 16th Mar 2016 9:36am
dorsetsmith
the only way i can see your radio working ign off
is to wire the red and yellow wires to the permanent feed
if this will not switch the radio on add switch red wire as the radio may need switched supply to trigger to start working
Post #514835 16th Mar 2016 10:22am
Mo Murphy
My new Sony HU is the same. It's wired correctly so I assume it's the HU. Not a problem though.
50 Shades of Pennine Grey
Post #514882 16th Mar 2016 11:45am
Bushpig
Thanks Mo
Yep, appears that the HU does only function through the switched live.
The permanent live is just there to stop settings, etc. being reset when ignition is off.
But have mailed Pioneer to see what they say... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #515186 17th Mar 2016 4:53am
Martin
Site Admin
Some ISO adapters have extra plugs and sockets on them so you can connect the aux (red) feed to the permanent (yellow), so the head unit stays on until you switch it off.
Check your adapter cable Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #515204 17th Mar 2016 7:53am
Bushpig
My ISO adapter only has:
1 red
1 yellow
1 blue/white
1 black
Guess I'll just have to live with it 'as is' for now... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #515253 17th Mar 2016 11:07am
spudfan
Ireland
Had the same issue and I e-mailed Pioneer and they sent this reply.
"Our head units have an ignition wire connection in their wiring loom and
will not come on unless the ignition connection is live.
Some OEM headunits are devised by the car manufacturer that they are not
dependent on this but all our product works in this manner." 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #515976 19th Mar 2016 2:12pm
Bushpig
Thanks Spud...
I've still not heard back from Pioneer Rolling Eyes
Did you find a solution or are you just using it as is?
Martin...
Do you think it would work to join the red & yellow wires?
Or would this just cause potential battery drain, other electrical issues or possibly blow the HU?
Happy Saturday Whistle Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #515981 19th Mar 2016 3:00pm
spudfan
Ireland
It's no big deal really as it comes on when the Land Rover is started. If we want to use it when parked up I just put the ignition key to the "power" position. 1982 88" 2.25 diesel
Post #515989 19th Mar 2016 4:06pm
Bushpig
Hi Spud
I used my vehicle for the first time at night and noticed that the HU lights do not dim when turning on the vehicle lights.
Does yours do the same?
Cheers Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #518704 29th Mar 2016 5:49am
spudfan
Ireland
Mine is the same, it stays the same. You can go into the settings menu and set the panel so that it is not as bright but the instructions are not the best. Good unit though! 1982 88" 2.25 diesel
Post #518732 29th Mar 2016 8:12am
They are wired like that to prevent un-intentional battery drain.
Which would inevitably happen with the best will in the world.
The blue / white wire is the remote or RMT12v, it's used as a live switch for turning on an Amplifier.
Make sure the bare wire isn't exposed if not used as it is live.
Post #518736 29th Mar 2016 8:28am
spudfan
Ireland
Thumbs Up Thank you. I don't bother with the remote. 1982 88" 2.25 diesel
Post #518740 29th Mar 2016 8:40am
