Home > In Car Electronics > Switch basics - rear air conditioning |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 |
It depends entirely on the system and how it's controlled. I assume it's an aftermarket thing?
16th Mar 2016 7:44am |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 |
yes aftermarket. common in ASEAN countries so I suspect there was some sort of factory doing these mods
16th Mar 2016 10:36am |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
Can't help with your switch question but could you post some pics of the setup and do you know the manufacturer? Ray
16th Mar 2016 4:04pm |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
I have an aftermarket rear Aircon, the termostat is at the back but the fan speed and the compressor switch is at the front, Y just extended the wires from the normal fan system to my location in front. The wires run below the "carpets" (that plastic things we have on the defender) Augusto
Defender 110 TD5 2001 Discovery 4 TDV6 |
16th Mar 2016 11:02pm |
