![]() | Home > Tdi > 300tdi Double Core Intercooler fitted |
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 ![]() ![]() ![]() |
Yesterday, the Allisport Double Core Intercooler arrived. Beautifully made, by the way - and sooo shiny!
![]() The Bonnet Slam Panel needed a bit of cutting and the nearside panel needed opening out to accommodate the extra depth. ![]() Click image to enlarge ![]() Click image to enlarge I had tuned the FIP last week and it was still a bit smokey. I haven't tuned the FIP any more yet but right now the engine seems 100% transformed. I can make progress down the road with less right foot and when I need the power it's right there - no hesitation. EGT is currently around 540 degC maximum but generally sits around 300 degC normal running. I should've done this much earlier in my ownership but at �470, it seemed a bit steep. Now though, I've got to say I'm glad I bit the bullet. ![]() I'll try and edit to add some pics later - done. -------------------------------------------------------------------------------------------------- 1989 Defender 90 Toyota Aygo & Honda FR-V |
Have to agree. One of the best things I did to my 200tdi. Super modification.
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Interesting reading.
I had read that if you did just the intercooler with no pump tweak it makes it ;less powerful as it is effectively under fuelling. Will save up the pennies I think ![]() Self confessed mileage hunter ![]() |
Before I started any tuning, I recorded 470 degC when absolutely canning it
![]() The FIP Pin was then turned, starwheel turned, smoke screw turned, then Starwheel was adjusted a wee bit to keep the smoke sensible. I left the nylon washer/spacer in place for now. It was still a bit smokey on take-off and hard acceleration - so, probably still overfuelling. Max EGT was about 509 degC. Then the Intercooler arrived so instead of faffing about with more FIP tuning to reduce smoke, I fitted the Intercooler. I now have less smoke than before, but EGT is at 540 degC. I was expecting it to be lower TBH, but I'm quite happy with what it's doing. Nowhere near the figures of 690/700 degC quoted elsewhere. I also have a one box, free-flowing exhaust fitted so that should help keep the temp sensible. If you are fitting this Intercooler, it needs more fuel than standard, but as I said, it was probably over-fuelled before I fitted it. I'm sure I could tweek some more but very happy for now...then again, knowing myself, I'll tweek it again next week!!!! ![]() 1989 Defender 90 Toyota Aygo & Honda FR-V |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
i guess the colder air is making more use of the fuel with it overfueled hence the higher EGT with the I/C.
if it has been std it could well of been lower i guess. if it makes you feel better mine goes to 725.... Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
725
![]() ![]() ![]() ![]() ![]() Whoooaaahhhh!! All stop! ![]() 1989 Defender 90 Toyota Aygo & Honda FR-V |
yep, change up point! well its an auto but you get the idea! Cheers
