![]() | Home > Maintenance & Modifications > heated seats into a 300tdi |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I ran a another heavy cable (100+ amps) from the battery live to an additional fuse box that I mounted between my front seats under my auto console.
I then put a pair of Carling switches in the dash and ran power from a fuse on the additional fuse box to the switches and then down to the seat connectors. Saves trying to tap into existing looms and you know you have a sound set up with the correct loading for cables and fuses. I also run my heated screen from this fuse box and my light bar. All pretty simple to do |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
The diagram below may help. It's 2002 onwards but you'll get the gist ![]() ![]() Click image to enlarge |
Hopefully a much clearer pic.
