Home > In Car Electronics > Taking power from the clock loom (Puma) |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
I put one of these in my seat box to run extras off http://www.nippynormans.com/fuse-panels/fu...fuse-panel dead easy to sort out
11th Mar 2016 9:48pm |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 |
I can pull power from under the cubby as this is where the CB currently resides. However, I'm trying to cut down on the numerous cables running up behind the dash. Ive got loads already!
11th Mar 2016 9:50pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
You could go for a perm live from the radio loom? Or even the cig lighter? Although I can't remember if th cig lighter is permanent live or not.
12th Mar 2016 3:34pm |
Cig is switched mate. Clock and radio share a feed. Now tempted to use 4core and send the audio down that. Eg 2 Gnds a signal and +12v. Will need to faff a bit to get a fuse and splice in the signal from an audio jack.
12th Mar 2016 3:38pm |
You can decide yourself based on the fuse rating. IIRC, radio and clock are fed from fuse F29, which is rated at 15A.
Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
12th Mar 2016 4:15pm |
Was more wondering what the amp rating was of the clock harness.
Edited to add... PS its at position 30 fused at 10a. I suspect that picture is for a newer Puma. Mine is a 2010 2.4Ltr. |
12th Mar 2016 4:17pm |
Ah, OK. I always use this rule of thumb if deciding wiring diameters: mm2 = amps x length x 0,2.
So if the wire feeding the clock is 1 mm2 and length is 1 m or less, then it would be OK for 5 Amps. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
12th Mar 2016 4:26pm |
