Home > Technical > Help please Td5 |
1963bus Member Since: 01 Nov 2013 Location: Linc's Posts: 196 |
Hi all
I spotted a drip under my 2002 Td5 dripping off bell housing onto floor, I rushed round all the fluid reservoirs only to find no liquids missing I dried it all up underneath and put some card on the floor, started up and it started dripping again , caught some in a pot and found it to be diesel I took the engine sound proofing cover off and saw a drip from round the back of the engine, I took a pic from offside looking over wing and have put an arrow from where the drip is coming from [it's behind round thing] Any idea's please as I know nothing about these engines other than changing the oil/filters etc. Many thanks Brian Click image to enlarge |
12th Mar 2016 2:39pm |
Fuel pressure regulator, it's quite a common fault. Ray
12th Mar 2016 2:42pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Fuel pressure regulator leaking
You can see it Brian it's just to the right of the green arrow on your picture, with 3 pipes and an electrical connection. 3 x10mm headed bolts holding it on. Me personally, I use the £30 rebuild kits off eBay and have had 100% success with rebuilding them. Some people prefer to chuck a whole unit on for about £120......
12th Mar 2016 2:51pm |
Thanks again for quick reply, I'll have a look at the re-build kits [I'm not tight but just blown £500 on a personnel number ] sod's law something was going to go wrong
12th Mar 2016 3:18pm |
Nothing wrong with the kits. I'm not tight either but hate waste and I can't see the point of scrapping £100 worth of housing that there's nothing wrong with.
12th Mar 2016 3:23pm |
Cheers is it easy to re-build? any special tools?
12th Mar 2016 3:25pm |
A socket set with a 10mm socket and a pair of circlip pliers. Oh and a spanner to undo the return hose if yours is 2002>
12th Mar 2016 3:30pm |
Many thanks, will give it a go next day off [not dangerous using with a drip is it?]
Kit's seem to start from as little as a tenner, does that sound right? |
12th Mar 2016 3:37pm |
Some kits are just a load of 'o' ring seals and a gasket. Look for one that has the little round regulator as well as 100% that's what's leaking
12th Mar 2016 4:41pm |
Ebay iten eBay Item No. 171967832100 try that one
Cheers for the link and now watching it
I know it's from Spain but it probably comes from the same place most of the others do [here's hoping] Thanks for your help, leak scared the hell outa me this morning, now looking forward to the fix Brian |
12th Mar 2016 4:57pm |
The good news is it's a hell of a lot easier to do on a defender than a disco
12th Mar 2016 5:01pm |
glad I didn't buy one of those then
12th Mar 2016 5:02pm |
