Home > Maintenance & Modifications > Defender 90 softop conversion to hardtop - parts doubt!!!
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
hi gents,
I am converting my defender 90 2005 softtop to hartop using a 1999 hardtop and i have the following doubts before my attempted fitting tommorrow.
I am not sure about the foam and rubber seal needed but came up with this list:
1-MTC 4994 (rubber seal upper hardtop)
2-MTC 6568 (foam seal windscreen)
3-MXC3684 (seal body side right)
4-MXC3685 (seal body side left)
is that all i should be concerned with?
On the other hand i have another doubt on the rear foam between the capping and the hardtop, found 2 references
1- ALR5056.......................seal same for both sides defender from 91 to 01
2- AML710070,AML710060.....seal for each sides defender from 2001 onward
my question my defender is a 2005 and hartop is 1999 which seal should i go for ?
does it depend on car body or hardtop?
thank you for your valuable help on this, the big day is tommorow.
Bow down Happy Travel
www.thegippo.wordpress.com
Post #513187 11th Mar 2016 1:03pm
jst
in the scheme of things i dont think it will really matter Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #513319 11th Mar 2016 6:54pm
sherifsalem
Hi James
meaning it is not a big deal they will fit regardless the body and hardtop right!!!
for these 2 seals
would you know if they should be one on top of the other or paralel to one another.
https://www.landyzone.co.uk/land-rover/roof-seal-question.115523/
unfortunently not clear but closest i got Happy Travel
Post #513418 11th Mar 2016 11:47pm
sherifsalem
Started with a little bit of difficulty, I have gaps between the hardtop and capping and front rooftop to windscreen side gaps.
All the bolts were tight as much as we could but still the seal it touching the capping very slightly.
What can I use besides the orginal sealing???
 Happy Travel
Post #514004 13th Mar 2016 9:08pm
