![]() | Home > Maintenance & Modifications > CTEK BATTERY CHARGER Recon program |
I had exactly the same happen, I kept resetting the CTEK and after a couple of days of resets it eventually started on the cycle and brought the battery back to life
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3653 ![]() ![]() ![]() |
Thanks Go Beyond, I have reset about 5 times so far in the last 24hrs will persevere a bit more before giving up.
![]() I hope everyone is well and your land rovers make you happy |
Nothing to lose ....
Update on this is that the CTEK will not recover the battery I gave the battery a shake and it cycled through the recon program once but has repeatedly failed again since, the battery wont hold more than 12.2 volts so ended up buying a new battery which will be better treated than the old one. DEFENDER 90 TDCI XS,
