Home > Maintenance & Modifications > What Have I Done???
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
What Have I Done???
Hi folks,
A quick question......
I replaced my plastic headlight surrounds & Grille earlier in the week.
The previous owner had wired the sidelights & indicators up without using any connectors to allow me to unplug & remove, so I had to cut the wires, solder on connectors to allow me to get the job done satisfactorily
The drivers side job was no problem and when I re connected everything it all worked without fuss
The passenger after doing the exact same thing isn't working.
No sidelight or flash from the indicator.
The repeater on the nearside wing is OK (well flashing quickly but I accept that because the front isn't flashing)
I cut the nearside wires for the sidelight & indicators using pliers (so positive & negative simultaneously)
Ignition wasn't on, could I have popped a fuse for the indicator and sidelight?
Front end all fresh looking but also faulty!!! Crying or Very sad
It's an '88 200tdi if it matters.
G My confidence has been writing cheques that my abilities can't cash for years.
Post #512989 10th Mar 2016 9:10pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Have you got a fluke/multimeter to check for voltage? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #512999 10th Mar 2016 9:28pm
Enid_Puceflange
Unfortunately not
Will see if I can borrow one from a technician at work My confidence has been writing cheques that my abilities can't cash for years.
Post #513000 10th Mar 2016 9:33pm
Mash
If you can get one, there is a connection block located on the inner wing, if you disconnect it there you can see if you are getting voltage, if you are it will just be a case of doing continuity test of the cables from this block to the lights. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #513001 10th Mar 2016 9:36pm
Enid_Puceflange
Smashing,
Thanks for the info.
Is that an outer wing off job? Embarassed
Post #513011 10th Mar 2016 10:01pm
Mash
You should be able to reach them through the engine bay, worst case would be taking the eyebrow off. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #513016 10th Mar 2016 10:13pm
Screbble
Can you get to the area via the wing top vents?
Post #513017 10th Mar 2016 10:15pm
Mountain_man
Wales
my guess is that you have dislodged a bullet connector from the common earth block.
Post #513023 10th Mar 2016 10:21pm
shaggydog
I'm guessing you did check the fuses? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #513024 10th Mar 2016 10:22pm
Enid_Puceflange
Everything was working perfectly before I started the job ( I did check)
But I haven't checked anything, I kinda just bolted it all back together, then walked off in the huff Laughing My confidence has been writing cheques that my abilities can't cash for years.
Post #513032 10th Mar 2016 10:32pm
Arran73
Sounds like a bad earth or crossed wires 1997 Defender 90 300tdi
Post #514889 16th Mar 2016 12:10pm
