Home > Maintenance & Modifications > Climair fitting problems
Alex1976
Hi,
I recieved a pair of Climair wind deflectors today (great service from Brendan!) and went to fit them when I got home.
They popped into the window channels nice and easy and within 2 minutes of opening the parcel they were fitted.
I can't seem to close the windows though. They go up to about 1cm from fully closed and the electric Windows then stop, presumably as the force required stops the motor. They feel a very tight fit and I am worried that trying to push the window in any further will result in something breaking.
I have now left them overnight in the almost closed position and hoping that they may start to settle in over night.
Any thoughts on this? Is it normal that they are this tight when new?
Cheers,
Alex
Post #512630 9th Mar 2016 9:11pm
leeds
Hi Alex, we have not experienced your problem.
Have you tried closing the electric window in stages?
Some silicone lubricant rubbed on glass on the inner edge of the Climair might help.That is about as far as I can go. If that does not help try ringing Climair on 020 8309 7744
Brendan
Post #512671 9th Mar 2016 10:46pm
JWL
In the deep recesses of my memory aren't some wind up windows thicker than others? I seem to have a vague recollection that the glass thicknesses changed over the years of the Defenders.
That might have a bearing on the problem.
Post #512674 9th Mar 2016 11:05pm
integrale
New Zealand
I recently fitted Climair wind deflectors to both front doors on my 2015 90. Straight-forward job. However, when the passenger side window is raised, the front of the glass is forced out of its channel toward the interior of the vehicle, about 6-8 cms from the top of the frame. Rear of the window fits and slides okay. Left the window closed to allow the deflector to settle for a week - in hot NZ summer weather - to no avail. Correctly fitted and the driver's side works fine. Just doesn't seem to be sufficient clearance in the passenger door channel. Possibly I need to adjust the channel "rake" but it's otherwise fine. Any ideas?
Post #512676 9th Mar 2016 11:42pm
Screbble
Re: Climair fitting problems
Alex1976 wrote:
Hi,
Cheers,
Alex
As Brendan says a little silicon lubricant will help.
I'd take them back out, clean and lubricate the runners with silicon lubricant, then pop them back in.
It might be worth checking to see if your door frame is distorted or misaligned.
Mine went in very easily and the windows weren't affected at all.
Hope all gets resolved Thumbs Up
PS they work a treat!
Post #513029 10th Mar 2016 10:25pm
Alex1976
Thanks for all the suggestions.
I have taken them out again this morning and cleaned and lubrictqed with silicone spray to help them all slide, but this doesn't seem to have helped.
It does feel like there simply is not enough room in the channel to take a Climair and the glass.
I wonder if I do have 'thick' glass as JWL has suggested?
I might wait for a warm/hot day to have a play with these and see if the heat will help with everything moving and settling to get them to fit better.
Post #513140 11th Mar 2016 10:48am
RRUK
My drivers side was awkward at first. Make sure you have definitely fitted it correctly at the front lower edge, it should be sitting ontop of the window rubber.
As the glass gets to the top, help it with your hand. It's likely that the channel needs to be forced apart for the first few times.
Mine now works fine after just giving it a helping hand and I didn't use any lube.
Having said that I don't like them fitted now anyway Big Cry 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #513145 11th Mar 2016 10:56am
geobloke
Huh, funny this topic should come up. I have just swapped out a set of HEKO deflectors from my 2002 Defender for CLIMAIR and now have the same problem. Darned windows struggle to close fully leaving a 6-8mm gap at the top "for ventilation"...
HEKO versions are made of a much thinner plastic and are much lower profile (does not protrude out from the glass as much) than the CLIMAIRs.
Will try the grease, otherwise it is back to the HEKOs
Post #513146 11th Mar 2016 10:57am
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I had a similar problem when I fitted them to a previous defender. In the end I widened the channel a bit by levering it apart Thumbs Up 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #513160 11th Mar 2016 11:52am
discomog
Had the Climairs fitted to my 90 SW a couple of weeks ago by Flatdog. I've not experienced any of the problems discussed above. You can however just hear the tone of the motor change when the window is within about 10mm of the top of its travel. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #513180 11th Mar 2016 12:51pm
jimbob7
This sounds like a good idea,mine just about hit the rubber then stop (manual windows). Pov.spec,ftw. 2006, 110,TD5.
Post #513228 11th Mar 2016 3:18pm
Alex1976
Yep I think widening the channel is the way to go (it sounds like UKIPs anti immigration policy).
I am going to have another go if the weather is warmer over the weekend and see what happens.
Post #513242 11th Mar 2016 4:09pm
landroverdiver
When I fitted mine I thought that the Windows didn't raise as high as they did before, but I didn't get the ruler out and measure them. There is no gap or wind noise, so all good. I will agree they are pretty tight.
Post #513283 11th Mar 2016 6:01pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Just fitted a set of fronts to my Puma, they were a pretty tight fit and more so than when I fitted some to my 1999 TD5. I guess the tolerance differences between doors can make a difference also that the doors have changed slightly between the older type doors and he steel versions. I don't remember the glass being tight at the top of the door with the TD5.
Post #616273 12th Apr 2017 11:11am
