![]() | Home > Maintenance & Modifications > roof protection with loaded roof rack? |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1033 ![]() ![]() ![]() |
treps Member Since: 07 Jul 2015 Location: SE Posts: 244 ![]() |
superb, exactly what I am after
I did search but obviously have not mastered it. Thanks again. I will order the panels on Monday Cheers |
Your welcome don't forget to post pics
Thanks again for the advice. Here are the pictures as requested - before and after.
It just took 45 mins to fit. Superb. I weigh 80kgs and I can easily stand on this. As mentioned, you have to avoid standing on the edges where there is no support but a brilliant solution nevertheless. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Looks very neat - do you know the weight of it?
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 ![]() ![]() |
2.5 kg per square
Thanks. I don't know the weight but it felt very light yet strong when fitting it. Is that 2.5 per square or per segment? A huge guess but I would assume it would be no more than 10 kgs total.
I used Screwfix cable ties (550mm). Easy and very strong. |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I wonder about using waffle boards then you have options if you get stuck and you can get relative cheap ones. Not sure the sizes work mind
Sorry mate per square segment
I ordered some of that, waited two months and had to stamp my feet to get my money back.
