Home > Td5 > What is this?
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
What is this?
Having a general poke about the motor today, I noticed this is a bit gunky with oil. My questions are this - what is it, does it need replaced if there is gunky oil round about it, should there indeed even be oil in amongst it? Is it an indication of other problems, or something more serious going on?? I look forward to hearing from those much more engine savvy than I - which is probably everyone on here Rolling with laughter Cheers.
Post #511300 6th Mar 2016 12:52pm
ibexman
Breather return
Post #511306 6th Mar 2016 1:03pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Yup, as Ibexman said,breather return.
They get gunked up.you can replace it or clean it out.
Thumbs Up
Marc
Post #511309 6th Mar 2016 1:12pm
RoddyK05
Thanks for the replies, if it's something that is going to happen 'regularly', I think I'll order one from Dan and just change it over, keep the other as a spare once I've cleaned it out. Cheers Thumbs Up
Post #511310 6th Mar 2016 1:17pm
dorsetsmith
LLN100140L - VALVE ASSY - DEPRESSION CONTROL TD5
Post #511313 6th Mar 2016 1:25pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
Hi All, mine is in a similar gunky mess on the outside, just looking for some advice from the engine guru's Smile . Can the valve fail internally and create the oily residue on the outside? Are there any symptoms if one fails? Should they be replaced at any stage in the engines life? Mine has 82k on the clock and I'm sure it's not been replaced before. Thanks Andy
Post #716583 7th Jul 2018 12:22pm
mk1collector
Add in a provent!
 Ray
My build thread
Post #716602 7th Jul 2018 4:27pm
AndyT66
Thanks Ray I'll look into one of those, cheers
Post #716621 7th Jul 2018 7:39pm
