Home > In Car Electronics > Universal dimmer module |
Yes there are, nevertheless many LEDs are not actually dimmable as they need a specific voltage threshold to strike up and illuminate. You may need to fit ballast resistors to achieve this. Best to buy a cheap potentiometer first and try it before spending time and money researching and procuring kit you may find won't work in the end. If you go through life with your head in the sand....all people will see is an ar5e!!
6th Mar 2016 8:29am |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 |
understood on the leds- do you have a link to such modules?
6th Mar 2016 8:36am |
You can use an LED as a light sensor by reversing it's polarity. You can also make your own from component parts all available from RS Components....
http://www.micro-examples.com/public/micro...ensor.html A DRL controller will also do what you want to achieve by dimming when the lights are on, you could perhaps adapt one of these for your purpose? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Mar 2016 4:17pm |
