Home > Maintenance & Modifications > Windscreen blocks
Page 2 of 2 <12
Nice photos Thumbs Up
Post #510974 5th Mar 2016 11:24am
nitram17
CDN38 wrote:
Clean it up, sure you'll find lots of corrosion in there... just did mine. Be sure to use LOTS of sealant. Run a bead around the outside diameter of all the holes, and then the outline of the gasket.
Are those holes in the bulkhead big enough to let a flexi cam through.iI was thinking of taking a look when it rains to prove the windscreen seal is leaking as my dealer denies this is a common fault and is unwilling to seal the windscreen as it is still under warranty and may lead to damaging the windscreen if it has to be taken out at a later date!
Post #510978 5th Mar 2016 11:52am
George G
The holes in the bulkhead have crush tubes installed so its unlikely you will be able to get inside the bulkhead from here. However if you remove the upper door hinge then you could get an endoscope through there. Hth
Post #511149 5th Mar 2016 8:35pm
Happyoldgit
Alternatively go in by removing one of the rubber grommets near the wiper arms. Steve.
http://forums.lr4x4.com
Post #511172 5th Mar 2016 9:27pm
nitram17
thanks mis..great idea!
Post #511181 5th Mar 2016 10:11pm
Page 2 of 2 <12
