![]() | Home > Maintenance & Modifications > Dead 06 plate TD5 90 |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
Open Filler neck, if you hear a "GULP" the breather is obstructed and the pump does not manage it to pump the fuel. WANTED:
SII or SIII in max 1.5k |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
When you say gulp, where are you hearing this, ear into the tank? Cheers |
Sharp knife, cut off ear, throw in tank......won't work BUT you will hear less wining and moaning
![]() You will hear it while you open the filler neck, sure. WANTED: SII or SIII in max 1.5k |
![]() Will pass that one on..... ![]() Any more idea's? |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
could be pump? if a cheap one was fitted,
![]() or warn through fuel pipes, snapped fitting from the top of tank / pump to filter. if the recovery man butchered the fuel lines then he'll need a new set....not cheap or easy to fit....or cheap to fit! anyway tell him theres a monkey here for it here ![]() |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 ![]() ![]() |
Injector seals are a very common problem...
£30 and an hour or two labour at the most. Ian |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6636 ![]() ![]() ![]() |
Fuel pump relay faulty/burnt out contacts?
Fuel pump was shot......
It had been replaced last month with a non OEM part....... Cheers for everyones feedback ![]() |
apmoore1976 Member Since: 04 Jan 2011 Location: Glos. Posts: 11 ![]() ![]() ![]() |
Thanks TC for asking about...
Always, always, always get geniune fuel pumps - the britpart (and others) have failure rates hitting 90%+...also airflow sensor was also shot! Injector seals were replaced a few months back (they're good for 50k miles) but as the song goes...On the road again!! ![]() 06 Defender TD5 CSW Silver LE |
Don't listen to a word he says, I had to draw him a map from the drivers seat to the engine. The plate of metal between him and the engine only confused matters. Go and say hello on the introduction thread Mr Moore sir ![]() |
Takes your monster offroad yet???
Up the kerb and down the kerb EVERY day..... ![]() |
