![]() | Home > Technical > Alarm goes off during hail shower or heavy wind |
water getting to A pilers shorting switch (remove the switch spray with WD40 re fit the switches )
Do have cabin sensor in the head lining drivers side (heavy hail can set off) |
molecatcher Member Since: 10 May 2015 Location: preston Posts: 10 ![]() ![]() ![]() |
Hi
where can I find the A pilers shorting switch? The cabin sensor is in the headlining on the drivers side. |
open drivers and passenger doors one switch on both sides just below front speakers in the A pillars this switch also operates the interior lights
![]() Click image to enlarge you may have switch on rear door driver side pillar too http://www.landroverweb.com/Pdf-files/Manu...Manual.pdf |
Thanks very much I appreciate the help you have given to me
