Home > Technical > Defender horn problem
Gordon Bennett
United Kingdom 1998 Defender 110 300 Tdi CSW Bonatti Grey
The horn on my 300 tdi defender suddenly just came on and I had to disconnect it to stop it .the alarm was not active at the time so has anyone have any ideas what the cause might be? Thanks for any help in advance.
Post #484184 21st Dec 2015 2:04pm
dorsetsmith
the link may help you
check horn switch by removing fuse 2 passenger side if the horn stops sounding you have a problem switch on the steering wheel
horn is also can sounded by the relay R200 driven by alarm with the horn connected find and remove the relay
Post #484189 21st Dec 2015 2:49pm
Gordon Bennett
Thanks for advice Having eventually reconnected horn today have found that all is normal but don't trust it not to go off in middle of night! I want to have detailed look at R200 relay and also horn switch and just replace both maybe. Hopefully find damp corrosion but I don't know where relay is on my 300 tdi csw so any help would be appreciated before I start to look in earnest.
Post #510312 3rd Mar 2016 12:21pm
