Home > Puma (Tdci) > Won't turn over. Cant connect to OBD. No main beam/dip
Soupy
HELP!! Major electrical gremlins!!
As title:
Won't turn over
Can't connect to OBD (I have a Hawkeye pro)
No main beam/dip
So far I have looked at the usual suspects (fuses, battery), all fine, not sure which relay is which so didn't want to just start pulling them.
Any suggestions welcomed!
It's a 2008 2.4 hard top.
Post #509626 1st Mar 2016 6:01pm
RED-DOT
Starter motor failure. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #509627 1st Mar 2016 6:04pm
Soupy
Hi, thanks for the reply.
Is that likely to cause multiple issues then?
Post #509628 1st Mar 2016 6:06pm
Cupboard
Hopefully this should link to a wiring diagram:
https://onedrive.live.com/?id=4BC2D89C85C7...9C85C7C171
Sounds to me like the supply to the ignition switch - does the dash "turn on" when you turn the key on? The OBD won't work until the ignition is turned on and the sidelights will work but no headlights until the ignition is turned on either.
Post #509950 2nd Mar 2016 1:43pm
Noiseydave
United Kingdom 2009 Defender 110 Puma 2.4 XS DCPU Santorini Black
Has similar on a 2008 90
Turned out to be ignition switch and a relay under the drivers seat but i can not remember which one
Post #509968 2nd Mar 2016 2:02pm
Soupy
Got there in the end.
Fitted a new starter (£150 Big Cry ) no difference.
Hooked the hawkeye to the AS10, there were about 5 immobilisers listed, one of which was enabled. Disabled it and she fired. Can connect to the ECU now too. Very Happy
Just the headlights to go Rolling Eyes
Post #509975 2nd Mar 2016 2:29pm
Did you fit the new starter yourself?
Given you had no power to the lights, I would have expected a garage to investigate that before swapping out a starter motor.
Not tried to do it on a Puma engine but could not not have ruled the starter motor out insitu by using jumper cables directly to it from your battery. OK the fuel pump and other systems may have prevented the engine starting but the starter motor may have kicked into life?
Post #510254 3rd Mar 2016 11:05am
RED-DOT
Ford starters are made of cheese and over worked. I reckon only a pickpocket could successfuly hit the +ve terminal without a firework display? Sorry if i misdiagnosed your fault. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #510290 3rd Mar 2016 12:35pm
Soupy
Fitted myself. I upgraded to a Bosch starter anyway so no problem really. Thumbs Up
The fault came back!! Evil or Very Mad with the immobiliser kicking back in.
Got to the bottom of it (hopefully).
Bad earth!
Post #510384 3rd Mar 2016 3:31pm
Soupy
F****** M*****F******* Piece of F****** S*** Evil or Very Mad
Won't start again!!
The temp gauge has gone shooting up and it won't turn over!!!
Post #510393 3rd Mar 2016 3:53pm
Soupy
Sorted phew!
Some wally (i.e. me) hadn't got the wires seated on the starter properly making a bad connection. Embarassed
Got it now though!
Post #510418 3rd Mar 2016 5:14pm
Soupy
AAAAAAAAAAAAAAARRRRGH!!!
Came in again this morning, won't turn over. Only dash light is the battery and the temp gauge shoots off the scale!
Big Cry
Post #510618 4th Mar 2016 10:44am
dorsetsmith
check all the earth connection
Post #510620 4th Mar 2016 10:49am
Soupy
All (all the ones I could find anyway) are clean and tight.
Post #510631 4th Mar 2016 11:40am
dorsetsmith
under driver seat is starter motor relay third one from bulk head end one side of the coil feed from ignition switch and other from ECU ind switch feed from link 5 60 amp red arrow see if this relay orange arrow is clicking then you try to start the engine if not, wiring, fuse or ECU stopping relay from operating and starter from tuning
see diagram below
YWB500060 part number from the this relay (spec for the relay is 12volt 40 amp)
if the relay is operates do you have multimeter to check volts out to the starter sol ?
see diagram below
Post #510689 4th Mar 2016 2:35pm
