![]() | Home > Puma (Tdci) > Advice sought - injector well cutting and injector re-use. |
WhathaveIdone! Member Since: 04 Feb 2016 Location: Sakhalin Island Posts: 27 ![]() ![]() ![]() |
I have recently acquired a defender Puma that has had a hard life. I identified early on that the injectors were blowing - I was struggling to tell exactly which ones as there was crud all over the top of the rocker cover. I have successfully removed the injectors (not without issues) and have managed to clean up the injector wells after improvising a plug.
The injectors and injector wells in cylinders 1 and 2 were fine. The bolt securing cylinders 3 and 4 was in poor shape (bent / starting to crack) and the copper washers had been extruded. Having now removed the injectors and the remains of the copper washers from the bottom of the wells, it is clear that #3 injector well is in poor shape and has an imprint from the bottom of the injector in it, probably because the previous owner 'fixed'it by overtightening the bolt. Injector well #3: ![]() Click image to enlarge Remains of copper washer - extruded out: ![]() ![]() I would appreciate advice on the following: - are there any dimensional checks I can perform after dressing the bottom of the injector well to verify that it will still seal after rework? - are there any workarounds (thicker washers / shims under clamp) in the event that the injector well is deeper than design? - I noted some small deformation of the nozzle tip on a couple of the injectors. The sides of the injector nozzle are no longer perfectly parallel. Is this acceptable or is any deformation cause for replacement? I was planning to reinstall them and give them a go on the basis that they were working previously. #4 injector - washer extruded around injector. ![]() Click image to enlarge - Is there anything else I should inspect while I have the rocker cover off that would be useful? Any tips or guidance appreciated! |
R1200GS Member Since: 12 Jul 2015 Location: Hampshire Posts: 265 ![]() ![]() ![]() |
Can anyone help?
Looks like this chap is a very long way from any LR dealer ! |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Got to be worth trying to reclaim the seat with something like this :
https://www.bodyshop-tools-supplies.co.uk/...GwoddzAHMg |
Well won't be getting to much done until I the weekend - I have a seat cleaner coming similar to the link posted above and I'll give it a go once it arrives. Will be interesting to see how it goes.
Will probably have to do a bit of digging first.... ![]() Click image to enlarge Will try and measure the amount of material i remove before i put it all back togethe, for future reference and in the event that the problems continue. |
