Home > Maintenance & Modifications > 2015 Defender - Battery tender required?
dunc
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
I'm often away for extended periods - up to eight weeks at a time. I have found many cars require hooking up to a battery charger/tender to avoid the battery going flat if left for a few weeks. What is the Defender like in this regard? Anyone use or recommend using a battery charger?
Post #509515 1st Mar 2016 10:36am
dorsetsmith
Post #509520 1st Mar 2016 10:47am
discomog
I use a Ctek MXS 5.0 charger/conditioner. I connect via the 13 pin towing socket. I don't tend to leave the Defender stood for a long time but I have one connected to a Morgan Plus 8 which spends most of the winter laid up and starts up first time. I also use one for a John Deere tractor as well and again never a problem with flat batteries. I can thoroughly recommend them, much more convenient (and compact) than a trickle charger. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #509523 1st Mar 2016 11:04am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I second the above statement, if you go for Check also get the "Comfort' (think that is its name) connector so you can have it permanently attached to the vehicle so you do not have to remove seat box covers etc. Thumbs Up Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #509526 1st Mar 2016 11:11am
dunc
Thanks for you comments/recommendations.
Just to confirm - do you all think it is necessary to keep the battery on the Defender on charge if left for extended periods?
Post #509532 1st Mar 2016 11:35am
dorsetsmith
good quality battery charger will float charge as part of it fauchon i.e. Ctek
solar panel charger is good option for float charging
Post #509536 1st Mar 2016 11:51am
discomog
Float charging (ie Ctek for example) rather than trickle charging is preferable if you intend to leave the charger connected for long periods. I have not experienced any problems or seen any reduction in battery life since starting to use this type of charger. It will also recondition your battery as and when required. Defender 90XS SW
Morgan Plus 8
Post #509541 1st Mar 2016 12:09pm
Cupboard
Whether you need one depends on what sort of other loads you've got on the battery. Split charge relay, Ultra Gauge, tracker will all use about 20mA each constantly, so that's 60mA total. 60*24=1.5Ah/day, 10Ah/week etc. which will flatten your battery in 8 weeks by themselves.
If you haven't got any of the above and just have the factory alarm going, I don't actually know how much that uses but the general consensus suggests about 30mA or 5Ah per week. Over 8 weeks that's 40Ah or about half your battery capacity. It might start, probably will assuming that's the only load and it's a decent battery.
I think I'd be putting a trickle charger on just for peace of mind.
Post #509578 1st Mar 2016 1:40pm
