Home > Off Topic > Stainless steel rust
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
I have just bought a new house and it has a swimming pool. The step handles are brushed stainless steel, I presume, but they have spots of rust on them. I think they are about 10 years old. Question is......if I take an electric wire brush to them will they come up like new?
Post #509450 1st Mar 2016 12:15am
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
Should do, but it sounds like a cheaper grade of stainless steel to me, maybe 304 grade? --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #509453 1st Mar 2016 12:29am
Cupboard
If you wire brush them, use a stainless steel wire brush. A mild steel wire brush will leave little bits of steel behind which will then start to rust and you'll be back to square one.
Most rusty stainless I see here is because it's been contaminated with non-stainless, although it's usually cosmetic rather than structural.
Post #509473 1st Mar 2016 8:45am
RED-DOT
This.... http://www.halfords.com/motoring/car-clean...olish-75ml 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #509486 1st Mar 2016 9:46am
I like Autosol - used the generic stuff from Halfords for many years, but recently I've purchased some of their other products that are not so widely advertised:
http://www.autosol.com/SearchResults.asp?Cat=1817
This might be the product for you:
I've got some aluminium polish and the anodized aluminium polish - just waiting for the nice weather to give them a go.
Bought both from here:
http://thepolishingshop.co.uk/acatalog/Bike_Cleaning-p1.html
Post #509496 1st Mar 2016 10:33am
Caterham
tis great stuff that autosol - been using it for 25 year Thumbs Up
one example
Post #509499 1st Mar 2016 10:36am
X4SKP
Hello jonno1968
If Stainless Steel then lightly 'polish' out and keep on top of it.
If Chrome Plated (brushed) Steel then you will just chase the problem until they are switched to Stainless.
As with everything Stainless Steel come in a wide range of qualities so if it displays a tendency to rust
it is almost certainly due to a lower quality base material being used, even the quality of the TIG welding
used will make a difference.
Stainless Steel generally contains elements such as Nickel and Manganese, but the main corrosion resistance
is provided by its chromium content. For example 18/8 means that this Stainless Steel contains 18% Chromium and 8% Nickel. 18/10 is 18% Chromium and 10% Nickel. The higher the numbers the more corrosion resistant the material. (trying not to give a metallurgy lesson here... Shocked )
From where you are try to use the least abrasive method to remove the rust, a wire brush can be very aggressive, very quickly, unless you scale it right down to a Dremel
Good luck... Thumbs Up SKIP
Post #509508 1st Mar 2016 11:04am
discomog
I'm indebted to Supacat for introducing me to Autosol Stainless Steel Polish. I've been using some of their other products for years but my polished stainless exhaust will certainly be having some SS polish treatment from now on. Thumbs Up Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #509528 1st Mar 2016 12:17pm
