Home > Td5 > Rear left tyre rubbing on spring support |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 769 |
He says that he has Boost alloys, but i am thinking the wheels may be part of the problem. Non genuine / poor copy wheel?
27th Feb 2016 5:48am |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
Hello all, more information coming.
The tires are, 245/75/16, the wheels are these http://www.paddockspares.com/boost-16x7-bo...-rrc.html, they have been there for 3 years aprox 150kkm. The axle is in line and it doesn´t steer on its own, dismounted the trailing arms and they are not bended, we changed the rubbers there when we did the A frame joint. The threads on the 4 bolts that hold the joint on the axle where bad so they told me they had to re thread them. I will put the money on the A arms, I will dismount them next week when I have some time and less heat (summer here) Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
29th Feb 2016 12:19am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2954 |
Looks like it been put back upside down the straight arm should be on left looking from rear?
29th Feb 2016 10:06am |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
Can the trailing arms be fitted back to front??
I have just been searching on axle offset and this popped up My rear axle looks like its about 1" offset in relation to the front axle, my tire after spacers fitted has the rear nearside wheel around 1" outside the wheel arch when looking from the rear, the offside looks to be sitting in by about the same, circa 1". The car is new to me, nothing looks bent underneath, everything looks square, nothing looks deformed and rear tub is nice and square as well. Lateral arms look square as well...... Cheers Andy |
11th Dec 2016 7:14pm |
