Home > Td5 > Rear left tyre rubbing on spring support
Page 1 of 3 123>
ajps72
2001 Defender 110 Td5 SW Chawton White
Helllo everyone; I have noticed lately that the rear left tyre on my 2001 110, rubs with spring support only on the left.
My wheels are boost alloy and tyre size is 245/75/16.
The distance from the spring aupport to the wheel is around 6mm on the left and 15mm on the right.
I have recently change the A frame joint and also had a problem with a broken bearing on the left some time ago.
Any ideas where to start?? Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #507866 25th Feb 2016 2:43am
Caterham
good luck in finding the problem.
is it possible the wrong bearings were used - could it have been an issue that occurred when the bearings were replaced (but simply not noticed at the time) or is it more recent?
Post #507918 25th Feb 2016 10:28am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Is there any play in the bearings? When you say the bearings were replaced some time ago I assume there was no issue in clearance and this has only recently started to happen. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #507924 25th Feb 2016 10:45am
ibexman
Top A frame bushes maybe has it been in a shunt Whistle
Post #507943 25th Feb 2016 11:43am
Can you post some photos indicating where you are taking the measurements?
Post #507967 25th Feb 2016 12:23pm
ajps72
Thanks for the replies, not sure if the problem was before or after the bearing change.
Thw bearing feels tight no axial play on the wheel,
I will take some pictures later on, but if you feel the inner top side of your tyre you could not put your finger because of the spring support. Augusto
Discovery 4 TDV6
Post #507972 25th Feb 2016 12:37pm
rustandoil
Something is quite wrong Shocked i have just been out to my Defender and there is around 25/30mm between tyre and spring mount.....
Post #507980 25th Feb 2016 12:51pm
ajps72
Shocked Shocked what wheels and tyres do you have??.......
Do I have a wrong axle?? Augusto
Discovery 4 TDV6
Post #507986 25th Feb 2016 12:56pm
Photos of gaps on mine:
Post #507993 25th Feb 2016 1:11pm
ajps72
your defender is so clean!!!!
I am uploading 2 photos, of the right and left side, next week I will check the bearings and stub axle Augusto
Discovery 4 TDV6
Post #508295 25th Feb 2016 11:46pm
The tyre size seems a little different to any sizes I've ever seen.
Are you sure it's not a tyre that is wider than should be mounted on a Boost alloy.
Post #508297 25th Feb 2016 11:48pm
shaggydog
There is something very wrong with this spring- its not meant to slope over to one side.
Looks like it is not seated properly at the bottom and is pulling the axle off centre
This I assume is the other side?
Looks like ether the a-frame joint is off or one or both springs are not seated properly/one is very bent. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #508301 25th Feb 2016 11:59pm
ibexman
This is a 15 year old car here my money is on either a shunt or A frame crossmember
Post #508313 26th Feb 2016 12:21am
JWL
I know it sounds daft but when the A frame joint was put back on you did use all the original arms? Looking at the way the axle is being pushed over it allmost looks like something such as the short arm from the ball joint has been bolted back on one side not sandwiched between the arms as in the picture below.
It's a while since I did one last and I can't remember if you can get the crank on the arms mixed up, might be worth a check
Post #508315 26th Feb 2016 12:22am
ibexman
I thought they were both the same
Post #508352 26th Feb 2016 9:08am
Page 1 of 3 123>
