![]() | Home > Puma (Tdci) > 2009 SVX 90 KNOCKING ON COLD START |
BBSJK Member Since: 12 Sep 2009 Location: Ledbury, Herefs Posts: 100 ![]() ![]() ![]() |
I had similar in the very cold but seamed to cure it by giving it a couple of goes on the preheat before starting.
jk No the other left . . . |
5wh Member Since: 01 Jan 2011 Location: Lancashire Posts: 37 ![]() ![]() ![]() |
Yes I gave it a couple of blasts of the glow plugs and that helped a little(the glow plug light seems to stay on a long time by modern standards),but even so the knocking was still there,just not as bad. 2009 SVX 90 Station Wagon
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Hi 5wh and welcome to the forum, is this your first diesel engine
Put 600-700cc of GOOD SYNTHETIC 2 STROKE oil before to make a full of fuel.........
then report to me......... it is vital fluid for the common rail system..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
_______ For the first treatment I agree, but are you saying to put this much in long term or as a one off ![]() I use basic motil 2stroke mineral oil from site sponsors OPIE OILS and find this ideal as per the advice from the freelander site. However I do have about 10litres of fully synthetic 2 Stroke in the garage for my outboard engines and didn't want to use it as it was of a high spec which isn't needed in the addition of diesel in my puma ![]() ![]() |
Synthetic is better than mineral because it remove the "laquers" on injectors produced by the "cooking" of the ashes.
Personally i add 2 stroke oil every 3-4 full of fuel during winter and every 2-3 during summer (more temp stress) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Never bothered changing the oil type. Interestingly the Citroen I run up and down the motorway has an 'auto' glow plug. Never seen it activate until it was showing -16 on the dash. Slight bit of knocking when it started. Christmas morning it showed -5 and didn't bother with any heat or knock.
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
Happy New Year from New Zealand, there has been talk here of using two stroke oil etc in the Puma engine but people here are wondering if it would damage the injectors as they are so small in the Puma engine rail
Any thoughts on this really really appreciated Simon |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
Few things I want to share with you all
The Puma has a common rail system , which means that fuel its pressurized at around 1600bar Common rail systems dont inject 1 time per stroke , multiple times actualy so itīs cleaner and most of the time more silently I think that if you crank your engine without any preheat , the little pre-injection sprays do not combust properly and will create a knock noise. now i know that the Pumaīs preheat system works as follow : when The engine head Temp sensor detects that the engine is under +-3c it will : preheat longer , and the glow sticks stay on a few seconds when the engine is running. to minimize those pesky emissions and optimize combustion . so I just let it preheat properly when my external temp is under 10c when its under 1 degree c i let it heat up twice . and when its really cold even 3 times. My Puma already has been to the dealer for new injectors ! if your puma still knocks after 1 minute ... take it to the dealer and complain My Dealer said at first , its normal its a diesel... I said that it didn't do it before ... but they kept saying it was normal ... they even said it was because i used Total Diesel Excelcium, with the Puma But then : my Puma was getting louder and louder . more smoky and beginning to act really weird . it was shaking at idle , if you drove with it and used your engine brake it would stutter... clearly signs of a ![]() in the end i wrote an e-mail to Land Rover Be-lux with my issues and then they solved it and they gave me an extra year of warranty on my engine ![]() tough , i would also be careful adding anything other then normal diesel in it , i heard some oils damage seals feel free to correct me ![]() |
1600 bar at maximum rpm and power. normally it work along a 350 - 1600 bar depending from rpm and power request (Throttle position)
5 times on FoMoCo Puma common rail
OVERVIEW The 2.4 liter diesel engine is equipped with a high-pressure common rail fuel injection system. With this fuel injection process, a high-pressure fuel pump delivers a uniform level of pressure to a shared fuel rail (also known as a common rail), which serves all 4 fuel injectors. Pressure is controlled to the optimum level for smooth operation, up to a pressure of 1600 bar. The system supports a pre-injection (pilot) phase, which reduces combustion noise and mechanical load. Fuel injection pressure is generated independently of engine speed and fuel injection events. The fuel injection timing and volume are calculated by the Engine Control Module (ECM), which then energizes the appropriate solenoid actuated injector. The common rail fuel injection system has the following features: High fuel injection pressures of up to 1600 bar for greater atomisation of fuel (increasing performance and lowering emissions) Variable injection to optimise combustion in all engine operating conditions Low tolerances and high precision throughout the life of the system The fuel system is divided into 2 sub systems: Low-pressure system High-pressure system The LP system features the following components: Transfer pump (located in the high-pressure pump) Fuel filter Fuel cooler The HP system features the following components: High-pressure fuel pump Fuel rail High-pressure fuel pipes Injectors Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
yeah right... |
