Home > Td5 > Disconnected pipes |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 |
Can anyone enlighten me as to what these pipes used to be connected to ?
Passenger side of my TD5 engine bay [URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] And while we're in mystery solving mode, what about these two thin plastic pipes (wire ? ) on the drivers side ? [URL=] Click image to enlarge[/URL] They seem to connect to this device on the inner wing ( drivers side ) [URL=] Click image to enlarge[/URL] Cheers :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
21st Feb 2016 12:07pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 919 |
The EGR pipes are just vacuum, you can take them out and plug the inlet on the solenoid. That was prettu shoddy workmanship. If you are going to remove a component, like the EGR remove it. The AC compressor has been removed but the pipework is very hrad and cumbersome to take out.
You put a plug on the solenoid like this. Click image to enlarge Your EGR removal pipe should look like is. No hoses or wires dangling about. Click image to enlarge That blue hose has been removed BTW 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
21st Feb 2016 1:21pm |
Thanks Chaps,
Glad I've got all this Aircon gubbins at the bottom of my dash board then I can feel a tidy up coming on |
22nd Feb 2016 2:43pm |
If the compressor is the only component missing from the AC you likely just need to replace it and charge the system..
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
22nd Feb 2016 6:38pm |
This is true as long as there's no leaks anywhere.
No rush though, It wont get turned on very often in Aberdeen |
22nd Feb 2016 6:45pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
I binned the A/C in mine. Frees up loads of passenger leg room (we don't require it much in Wales either )
22nd Feb 2016 7:17pm |
time for parts sale |
22nd Feb 2016 7:25pm |
