Home > Puma (Tdci) > Windscreen washer
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Windscreen washer
This is probably old news but thought I would share!
Been putting up with v weak jets for some time and been putting off repair but fitted a new plastic directional piece today. What a difference! Before adjustment of the directional nozzles I was washing the front section of the roof!
Dan at duckworth was not wrong about how hard it was to remove the external bit from the new fitting (which is why I had been putting the job off) however I fully recommend even if you only have a slight crack in the fitting it seems to really affect the power of the spray.
Something to be said for fully potent washer fluid to stop it freezing and cracking the fitting!
Apologies if you've all been there and already got the t shirt!
Post #503504 11th Feb 2016 4:01pm
