Home > Puma (Tdci) > Hot floor
MK
Hot floor
At least on LHD landies seat box struture gets quite hot during long trips (mainly summer). On RHD vehicles does the hand brake handle also gets hot? Puma 110" SW
Post #50286 30th Dec 2010 1:40pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
We drove cross continent last summer, from the UK to Romania, and not only did the handbrake get hot, but so did the metal under the seats. It was so hot that you couldn't really touch it for too long. It was amazing how hot it was in the cab, turning on the AC helped a bit but still... boiling!
Post #50289 30th Dec 2010 2:04pm
TJ101
Yep RHD also gets hot,,
Tip,, Shut the drivers window !!! won't then drag the heat up through California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #50309 30th Dec 2010 4:08pm
noworries4x4
When i am towing the Ifor in the summer and the viscos fan has locked up the handbrake seats ect become unbearable to touch, i dont have air con but sun roof removal helps If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #50393 30th Dec 2010 8:42pm
Naks
Re: Hot floor
Yep, standard feature on all Defenders Whistle
Post #50432 31st Dec 2010 7:05am
yep, my RHD TD5 and LHD TDCI floors heat up in the summer... almost too hot to touch
Post #50433 31st Dec 2010 7:08am
mse
Its not really been a problem for me but
has anyone tried to insulate the seatbox to reflect back the heat Mike
Post #50452 31st Dec 2010 9:37am
MK
Comparing to other trucks the landy is not different in terms of isolation. Well, the exhaust tube has less heat shields along. Defender tends to trap the hot air due to all the front facing shapes of the floor. I`ll give it a try with isolation foam and some homemade shields. NOt sure if it`ll work out as Al made panels are 4-5 times more conductive than steel.
In fact is quite unpleasant on long trips at 30ºC + Puma 110" SW
Post #50480 31st Dec 2010 11:52am
I wonder if dgardel's floor gets warm/hot, he has fitted the entreq underside plate, I'm wondering if this moves the air in a different way under the truck?
Post #50493 31st Dec 2010 2:45pm
