Home > Tdi > Timing belt kit |
sgilmour Member Since: 21 Jul 2015 Location: Essex Posts: 232 |
I'm looking to replace the timing belt on my 300TDi and am not sure if I currently have the old or new timing belt setup. I know the dealers were told to paint a little yellow square on the left hand side of the timing case when they had converted to the later type of setup due to the early belt failure problems but without looking I don't know if I have one there, or if it might have faded over time?
My question is: If I buy a kit with the new setup (specifically this one: http://www.rimmerbros.co.uk/Item--i-STC4096BM) and once I get the case apart find I have the older setup do I need anything else to change to the belt to the newer setup? Thanks, SG |
9th Feb 2016 1:02pm |
Thanks for the reply Alex1976. That's what I was trying to determine without taking the cover off first because I don't want to have to down tools and wait for parts to be delivered if I can help it.
Do you know if I order an "updated" kit but have an "outdated" one on there currently is it just a straight swap for parts? I've seen conversion kits available but I can't see what the bring to the party that a new kit wouldn't have already? |
9th Feb 2016 3:00pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 824 |
Did mine recently....
9th Feb 2016 5:18pm |
Click image to enlarge[/URL] Here is a picture of the old, original style parts compared to the newer, modified items. I can confirm that they are a straight swap. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
9th Feb 2016 8:21pm |
I forgot to say, make sure you take note of the reduced timing belt tension that was introduced to help combat the belt shredding issue. Haven't got the figures to hand right now but off the top of my head it is some thing like reduced from 14somethings to 11somethings.....
10th Feb 2016 5:06pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
If you have the old type and change to the new type you will need a front crank seal and the small o ring that sits in the back of the toothed inner crank pulley. I have done lots of these at work and if you don't change the above seals with the pulley they always leak
24th Feb 2016 6:43pm |
