Home > Technical > Very weird brake problem! Help please |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Never had a problem like this, as you said you have private land to drive on could you make some blanking plugs (I use old brake lines crimped and soldiered) and isolate each wheel station to try and isolate the problem to narrow your search. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
8th Feb 2016 11:32pm |
souster4 Member Since: 11 May 2014 Location: West midlands Posts: 153 |
Thanks for the reply mash.
I forgot to add in my post, last week I changed the existing stainless flexi hoses for goodridge, as I thought they were failing and they were the only options I had left. Before doing so, I clamped 1 front flexi at a time, and the pedal was better. I would say the pedal was 90% improved, with just a very very slight increase in travel when turning, which could have been my imagination . Both sides had the same results when clamped. This then forced me into tightening the bearings up to 40nm as I was convinced it was to do with the bearings. No luck! |
8th Feb 2016 11:49pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5842 |
A mate had a weird issue with his brakes on a E reg 110.
He would get a leak at the rear wheel cylinder on one side. Replace it and would OK for a while and then leak again. After lots of hunting/replacing he found there was a pressure valve/bias valve and this was causing the issues. Located on the bulkhead area if memory serves ( think it T off to the rear brakes and might have has a sensor on it?) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
9th Feb 2016 12:52pm |
I think it was a PDWA switch:
E04.040 FRONT - REAR DRUMS ('110"', LESS ANTI-LOCK BRAKING SYSTEM TO (V)HA901219 OR '130" WHEELBASE', LESS ANTI-LOCK BRAKING SYSTEM TO (V)HA901219) VALVE ASSEMBLY BRAKE, PDWA SWITCH, WITH FRONT DISC-BRAKE/RR DRUM BRAKE, LESS FT AND RR VENTED BRAKE DISCS Part number: NRC7871 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
9th Feb 2016 12:59pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2222 |
Presume your wheel bearings are correctly set (endfloat/preload)?
Can you not put the front axle on stands and take the wheels off to have a look at the calipers whilst turning the steering lock? A feeler gauge should give you a good indication of the pad clearance and if they are travelling back when steering. I have had similar issues with pedal travel due to caliper seals perishing and sticking to the pistons which causes pistons to retract too far when releasing pressure. Steve 02' 110 TD5 Double Cab Rebuild Thread |
9th Feb 2016 2:22pm |
Thanks for the reply mate. I've also replaced that valve too, granted a few things haven't been replaced just due to this issue, the brake system was in a terrible state when I bought it. But a lot have too! |
9th Feb 2016 4:43pm |
Thanks Steve. I've tried that with no luck. The reason being the issue doesn't show up when the wheels are stationary. So I think I'll have to do your suggestion, with all four wheels on axle stands and get the wheels moving. To see if I can see a problem, I'm hoping something will show up. |
9th Feb 2016 4:46pm |
