Home > Land Rover Customer Relations > Missing Grommets?
NJS22
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
Missing Grommets?
Will I went and bought a new 90 Adventure and I must say she is great leather everywhere. Then I noticed this,(see photo) two grommets missing from the snorkel, I phoned my dealer who then looked at his other Adventures in stock (big dealer) and said they are all the same.
You would think when you fork out £43k on a leather clad Defender they could afford two plastic grommets.
 1998 90 50th Anniversary 4.0 V8
2016 90 Adventure
2015 Range Rover Sport
1971 Range Rover 2 Door
Wife won't let me have any more...!!!
Post #501582 7th Feb 2016 10:59am
YOLO110
Australia
Pants!
Give 'Mantec' a call.
They make this RAI and will have spares. FOC I am sure too! YOLO... You Only Live Once...
Post #501601 7th Feb 2016 11:25am
stanley
Who signed off the PDI?
Post #501605 7th Feb 2016 11:27am
YOLO110
Australia
Someone who is now working on the RRS line! Laughing YOLO... You Only Live Once...
Post #501615 7th Feb 2016 11:35am
Shocked
Had my main dealer tell me this on several issues - are they trained to give you this vacuous response? Is it right or wrong, is something missing or is there an explanation is what is required.
Post #501642 7th Feb 2016 12:24pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Had the same with my Mantec. Pop into your local electrical supplier and ask for 20mm grommets used for 13 amp socket back boxes. These should fit a treat. I only have one kicking around otherwise I'd have posted a couple off to you.
 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #501681 7th Feb 2016 1:43pm
ericvv
Re: Missing Grommets?
Tell your dealer to either get you those, or otherwise get written confirmation from JLR headoffice that these RAI are supposed to come from the factory without these grommets. It is small things, but no reason to accept such dealer answer.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #501695 7th Feb 2016 2:20pm
NJS22
Cheers Rustyboxx easiest way I expect. 1998 90 50th Anniversary 4.0 V8
2016 90 Adventure
Post #501696 7th Feb 2016 2:26pm
NJS22
Eric
They aren't my normal dealer although I did buy a 90 HT from them last year, it seems the box standard reply.
I will be seeing their sales manager or DP in a couple of weeks when she goes in for waxoiling, nas bumper and tow bar as that is not acceptable. 1998 90 50th Anniversary 4.0 V8
2016 90 Adventure
Post #501699 7th Feb 2016 2:31pm
Swac3
Doesn't look like they're BS'ing you when they say they're all like that, even the motor show one doesn't appear to be finished off.
 3 Landrovers
Post #501705 7th Feb 2016 2:53pm
ericvv
Swac may be right. Checked pictures of a few for sale here in Switzerland, and seems there are no grommets here either. So might well be that it indeed is supposed to be like that. The good news about that is that it gives you a chance to a cheap and easy upgrade. Laughing Thumbs Up
Post #501713 7th Feb 2016 3:05pm
NJS22
Fantastic I can do another mod Rolling with laughter 1998 90 50th Anniversary 4.0 V8
2016 90 Adventure
Post #501721 7th Feb 2016 3:20pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
The instructions are in this thread here -> http://www.defender2.net/forum/post310098.html
No grommets so I suspect the 'aftermarket modification' will be required... Whistle
I'm still nursing the missing skin and general blood loss from fitting a Safari Snorkel and a Nugget sealed air box over the weekend Rolling with laughter Dave
Green Goddess - 1998 Defender 110 300tdi
Post #501737 7th Feb 2016 3:55pm
dorsetsmith
its not mod it enhancement Whistle and 20mm blind grommets CEF will be cheaper than parts from LR Whistle
Post #501740 7th Feb 2016 3:58pm
Having not looked too closely at the fitting instructions before, I'm even more put off the product - only two lower fixings and you have to drill into the wing for them - yet the gasket and the RAI appear to have holes for 4 fixings?
Earlier versions had 4 fixings and better still they went into the area of the wing exposed when the original cover was removed.
Post #502075 8th Feb 2016 11:53am
