![]() | Home > For Sale & Wanted > [Wanted] Anyone got a flatbed trailer they'd rent to me for |
spags Member Since: 10 Jul 2010 Location: Tulliallan & La Vernaz Posts: 23 ![]() ![]() ![]() |
I have a large Ifor Williams twin axle flat bed, tilts and has drop sides that could do the job. Is it for private use or business as that dictates need for tacho and operator license? Also important that it is loaded correctly and strapped down to meet any VOSA inspection. (your safety and that of others)
Located at Tulliallan between the Clacks and Kincardine bridge. Overall length inc of drawbar is 6m Width Platform 1980mm/6’5’’ Length Platform 4870mm/15’11’’ Loading Height 640mm/2’1’’ Internal lashing rings Gross weight inc payload is 3500kg PM me for more info and direct contact mobile. John |
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
If you're lucky you may find that a local farmer has a flatbed trailer you might be able to borrow, if you can't find one suitable on here. Any farmer that moves hay bales around will probably have one- I buy hay/straw from a farmer & he uses a 16' Ifor flatbed to deliver. Mark S
CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
allyjbull Member Since: 16 Nov 2010 Location: Northumberland Posts: 74 ![]() ![]() ![]() |
Hi Mike
Have you tried Whiteside Trailers at Airntully near Perth? I've hired horse boxes off them a few times and I'm pretty sure they have flat beds. Might be a bit out of your way but worth a punt if you're stuck. Allan |
