![]() | Home > eBay & Bargain Spots > eBay Grille sets |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Bought the last one
![]() KBX set soon to hit the for sale section!! Cheers Andy |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
I bought a set at the new inflated price
![]() I'm getting some Wipac crystals to go with as well. Will look smashing! |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
Are these just painted or is the plastic actually Santorini Black?
Postage to Italy doubles the price of the item ![]() |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Painted! try searching on here as i think someone has done it before i think it needs good prep and the finish still looks like its been done at home!but i could be wrong!..there must be some spray bods on here who can advise you about spraying plastic?
Yes they are just painted. I did mine myself
![]() Click image to enlarge ![]() Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
some questions ...How did you prep the plastic mk1 do you think youve got the finish as goood as new ?Was it cans or sprayer?looks good in the photo!
Rub the plastic down thoroughly (I used 800 grit paper) then degrease. Next use plastic primer, get a few light coats on leaving to dry in between coats. I then put on a couple of coats of high build primer and let completely dry before flatting nice and smooth then degreased again. I used 2 pac base coat aerosol from a local paint supplier then 2pac clear. Luckily it didn't need flatting and polishing when dry but I did the spraying on a nice warm day and have had a little experience. Ray
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20673 ![]() ![]() |
Ideally gotta be a stable temp of a min 15C to around 25C. Ideally approx 18C -22C is ideal.
Everyone has different ways of painting and everyone gets mixed results, the grille is the hardest yo do due to its awkward shape. |
Where is the best place to get a few cans of Santorini black?
Local motor factors usually sell the 2 pac aerosols Ray
Yannis - Take a look here, would save you the trouble of running about.
Delivered to your door. http://www.ebay.co.uk/itm/271658207263?_tr...EBIDX%3AIT |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1179 ![]() ![]() ![]() |
Eventually got mine fitted today.
Massive difference , the front was a bit tired to say the least [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] You get the idea 😉 Think I will take the headlight protectors off to give a coat of gloss Plasticote Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
7heaven Member Since: 03 Feb 2016 Location: Oxfordshire Posts: 122 ![]() ![]() ![]() |
Just ordered a set
![]() Love the Black Pack look ![]() 2015 90 XS Station Wagon (sold) 2010 110 XS Station Wagon (stolen) |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 ![]() ![]() ![]() |
Just got mine and fitted. Looks so much better
Before: ![]() Click image to enlarge After: ![]() Click image to enlarge 2003 Defender TD5 Hardtop (current - work in progress) 2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
