Home > Maintenance & Modifications > Drain plug gunk , transfer box status assessment
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Hi All,
So I have changed the oils on my puma 2.2 defender today. she has done 48,000Kms and a MY13
and I found this!:
well, this is my first time doing oil change myself so please tell me how bad it is or its normal....
many thanks
Martin
Post #500695 5th Feb 2016 1:34am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Looks ok to me, you always get a small amount of swarf on the drain plug (magnetic for a reason). 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #500749 5th Feb 2016 8:53am
YOLO110
Australia
Very surprised there is still swarf after 48,000 km and presumably at least 2 other previous oil changes??? Shocked YOLO... You Only Live Once...
Post #500801 5th Feb 2016 11:29am
Probably not 2 changes on transfer box oil - that could be from new.
More should post photos like this and then we have a really valuable knowledge base. Thumbs Up Thumbs Up
Post #500901 5th Feb 2016 3:56pm
Retroanaconda
If you start finding chunks of teeth or synchro rings then you can be more concerned, but that is perfectly normal.
The LT230 is a pretty robust beast.
Post #500911 5th Feb 2016 4:29pm
tuesdayfox
Thanks everyone. that was a relief.
yes, this was the first oil change for gearbox, transfer box and both axles.
in my case, 48,000kms in 3 years two big trips and approximately going offroad once a month:
-the gearbox oil seems fine, the oil is dark red colored and doesn't smeel too bad. (I measure the dropped oil and mine was under-filled from factory)
-the font axle oil is brownish black and the rear axle oil is also brownish black with quite a bit of bubbles in them.
-the transfer box oil is the worse. it smells really bad and its sort of a think, also silvery black colored.
I think I will be getting a magnetic plug for my gearbox soon and change the transferbox oil more frequently- workshop manuals says tbox oil changed at 80kkms and gearbox oil changed at 200kkms.
Martin
Post #501576 7th Feb 2016 10:38am
