![]() | Home > Puma (Tdci) > Puma alarm indicator |
Doubledoom Member Since: 27 Dec 2015 Location: Suffolk Posts: 42 ![]() ![]() ![]() |
It doesn't on mine. So, that would suggest an issue.
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
not on mine either may need a diagnostic alarm or immobilizer issue by the sound of it is it `running ok
jbc sorry you said it was running ok just done a bit of research check the battery in your key fob it could be the battery is low and need replacing
Mine's done it from time to time - so you are not in a class of one.
It's only the briefest of flashes, so maybe easy to miss if your eyes are elsewhere. It's not led to any other issues and I don't know whether it would store a DTC for it if i had the kit to check? |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 ![]() ![]() ![]() |
My 2013 Defender alarm flashes a few times a year. I have never had any dramas so just tend to forget about it. From memory, it is a single flash which just catches my eye whilst driving. The Defender doesn't miss a beat.
MY12 Workshop Manual: "If the remote handset battery falls below a pre-determined level, the handset will transmit an additional RF signal code to the anti-theft system module. This signal is relayed to the instrument cluster indicator which emits 2 rapid flashes every 0.5 seconds to inform the driver that the remote handset battery needs replacing." My best guess is that it's to do with the Central Door Locking feature whereby the alarm light illuminates for 10 seconds if the driver's door is opened. Assuming it gets this signal from the driver's door switch and the switch operates with the slightest of movement then a random bump in the road could cause the momentary jiggle in the switch to operate the light. I haven't checked this out - but if you open the door slowly, see how far you get before the light comes on to rule this in or out. |
