Home > Maintenance & Modifications > Heated Washer Jets |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 |
I know someone who had one Mick - they loved it. You need to set up a power supply with a time switch, or just remember to turn it on before you leave.
Similar to an Eberspacher / Webasto fuel burning heater but clearly not viable if you'll be away from power. My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
20th Dec 2010 12:16am |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
see new post on AlphaTHerm installation |
20th Dec 2010 1:26pm |
tacr2man Member Since: 02 Oct 2008 Location: J10 M40 Posts: 20 |
They were standard fitment on rangerover Tacr2a RRV , they work well , but are generally pretty expensive to buy , as are quite sought after . You also need to be able to plug into mains whre you park by the way ! I have a similar USA sourced item for that reason on my V8 110 |
28th Dec 2010 10:39am |
3000W!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
28th Dec 2010 10:46am |
