Home > Puma (Tdci) > Service Recalls & Bulletins
Naks
Hi guys,
Hope you all had a good Xmas and the babelas did not hit too hard! Cool
Does anyone have a list of all the service recalls & bulletins for the Puma? Mine is going in for its first service at the end of Jan and I just want to make sure all the required fixes are done.
thanks!
Post #49949 28th Dec 2010 8:24am
Naks
ps. we can make this a sticky for future reference?
Post #49950 28th Dec 2010 8:50am
Grockle
check the vac pump for a leaking pulley seal,some sumps have been changed due to contacting with the front axle, ecu updates qv version 2 and 4 dependent on chass range............ 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #49951 28th Dec 2010 10:13am
nakatanenga
Germany
Got them all....in German language Sad WANTED:
SII or SIII in max 1.5k
Post #49954 28th Dec 2010 10:50am
Naks
Please can you post them here, Google can translate Thumbs Up
Post #49955 28th Dec 2010 10:52am
mse
Post #49960 28th Dec 2010 11:39am
dgardel
Italy
Not all but the most important :
Nr 1)
Technical Service Bulletin
No.LTB00177
09 October 2008
Subject/Concern: Brake Vacuum Pump Seal Oil Leak
Models:
Defender (LD) 2.4L Diesel Only
2.4L Diesel Only VIN-range: 7A732615 Onwards
Markets: All
Section: 206-07
Summary: Oil leaking from the brake vacuum pump front oil seal.
Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31.
Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07 (70.15.19)).
Parts Required:
Description Part Number Quantity
Brake vacuum pump LR012183 1
Gasket LR004381 1
Labour Time:
Operation Description Operation No. Time
Install a new brake vacuum pump 70.15.19 0.7 hours
Repair/Claim Coding:
Causal Part: LR012183
ACES Condition Code: 42
Defect Code:
Nr.2)
Land Rover Service Bulletin SSM38792, 2.4 Puma Engine Knock Noise.
Title: 2.4 Puma Engine Knock Noise.
Type: LD - Defender - All Years - Special Service Messages - Engine
Name / Part No: SSM38792
Info Type: Service Bulletins
Version No: 1
Date Uploaded: 21 Jul 2008
Models: LD - Defender
Last Modified: 21-JUL-2008 09:44
Category: Engine
Symptom: 497000 Engine Noise
Content Issue: Heavy audible knocking heard on start up.
Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur.
Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used.
This condition will not occur on vehicles post assured Vin# 9A767162.
Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.
Nr. 3)
SSM39893
Models
LD - Defender
Title Defender Intermittent Cranking
Last Modified 26-NOV-2008 16:29
Category Electrical
Symptom 203000 Basic Electrical
Content Issue:
Warranty investigations have shown a number of repairs to Defender for intermittent loss of cranking.
Cause:
This issue may well be due to the immobilisation strategy on Defender.
Action:
Before conducting any work on a vehicle with this symptom, please view SSM 34184.
Nr.4)
SSM38084 Models LD - Defender
Title Defender MA 07 - lock in one gear
Last Modified 06-MAY-2008 11:27
Category Transmission
Symptom 505000 Manual gearbox anomalies
Content
Reference: MT82 Getrag gearbok locked in one gear.
Cause: Still not determined.
Required action: Land Rover ask to the dealers to confirm the problem first and proceed to fill the attached questionary before to get in contact with the "Fix Right Enhanced Diagnostics" (FRED) technichians in charge of the repairs. Thats will allow to the enginnering dept to understand the possible causes of the problem.
Nr.5)
SSM40851
Defender Front and Rear Propshaft Grease Points
Models : LD - Defender
Title: Defender Front and Rear Propshaft Grease Points
Last Modified: 30-MAR-2009 08:27
Category: Noise/ Vibration
Symptom: 703000 Vibration Concerns
Content Issue: Loose or missing front / rear propshaft grease nipples for Defender 07 MYonward vehicles.
Action: If any propshafts are identified where the grease nipples are missing, then the propshaft should be replaced. Any cases where the grease nipples are in place but loose should be torqued to 8Nm + 45degrees.
Nr.6)
Models
LD - Defender
Title P1169 and or P0089 codes logged.
Last Modified 30-JUL-2008 10:16
Category Driveability
Symptom 608000 Runs Rough
Content Issue:
07MY onwards - Difficult to start, missfire, lack of power, driveability issues etc.
PCM can have either P1169 and or P0089 logged codes.
Pre assured Vin# Def 90 at Vin LD8A760582. Defender 110/130 at Vin# LD8A760304.
Cause:
Potential contamination in the fuel system.
Action:
Remove the fuel filter, drain complete contents into a suitable clear vessel. Note signs of any water contamination / debris. 1) If more than 40cc of water or debris is evident carry out the following:-
Drain the fuel tank.
Check the fuel tank breather location and reposition as per the illustration A attached.
On pick up variants please reposition the breather pipe in board towards the rear of the fuel tank.
If breather is blocked replace the pipe as per GTR.
Replace the fuel filter and clean out the fuel lines of any contamination / debris and or residue.
For P1169 code replace the FMV (Fuel Metering Valve), as per GTR and LTB00153. Illustration B.
If DTC P0089 is also present replace the PRV (Pressure Relief Valve), as per GTR. Illustration C.
Bleed and prime the fuel system as per GTR.
Start the vehicle and carry out the pump learn process with IDS as per GTR.
Carry out a road test to ensure the issue has been rectified and no codes have been logged.
Submit any findings on ePQR to engineering.
2) If no sign of water or debris but either codes logged carry out the following:-
Check the integrity of the wiring and the condition of the terminal connections between PCM and Fuel Rail Pressure Sensor and between PCM and FMV. Repair wiring as necessary and re test the vehicle.
If no issue is found with the wiring / connections, and code P1169 logged, replace the FMV as per GTR and LTB00153.
Replace the fuel rail PRV (Pressure Relief Valve), only If DTC P0089 is present as per GTR.
Note:-
A new tank / breather design was introduced on Defender 90 Vin# LD8A760582. and Defender 110/130 at Vin# LD8A760304.
Please submit an ePQR for any issue seen on vehicles post these vins.
Nr.7)
SSM40308
Models
LD - Defender
Title Mulitiple Starter Motor Failure
Last Modified 21-JAN-2009 17:43
Category Electrical
Content
Issue:
Repeat failures on Defender starter motors.
Cause:
The ignition switch can jam causing starter motor failure due to over running.
Action:
If the starter motor has failed check operation of ignition switch;
a) Is the switch jammed through any of its positions?
b) Does the switch fully return to position 2 once cranked and the inhibit operates, not allowing re-crank from position 2?
c) Does the starter motor continue to engage once cranked and key released?
If the answer to any of the above is YES please change ignition barrel as well as starter motor as potentially the starter motor will fail again.
Vehicles post vin. 775971 have been modified and should not demonstate this concern.
Nr.Cool
LTB00166
Subject/Concern: Clutch Noise/Poor Selection
Models:
Defender (LD) 2.4 Puma Diesel Engine. 2.4 Puma Diesel Engine. VIN-range: 7A732615-9A766150
Markets: All
Section: 308-00
Summary:
Potential difficult gear selection and noise in clutch operation.
Cause: Improvements have been made to the specification of the clutch plate and clutch cover to
address both the potentially difficult gear selection and noise during clutch operation
concerns.Suggested customer concern code P24.
Action: Should it become necessary to install the clutch kit assembly, refer to the new procedure
detailed in Global Technical Reference GTR Workshop Manual, section 308-00.
Parts Required:
Clutch kit Assembly. URB500080 1
Labour Time:
Clutch kit Assembly Renew. 33.10.01 3.9 hours
Causal Part: URB500080
ACES Condition
Code:
Nr.9)
Technical Service Bulletin No.LTB00211
30 April 2009
Subject/Concern: Transmission Stuck in Gear, Selector Shaft Detents Now Available
Models: Defender (LD) 2.4 Puma Diesel 2.4 Puma Diesel VIN-range: 7A732615 Onwards
Markets: All
Section: 308-03
Summary: This Technical Bulletin is to advise that the transmission selector shaft detents are now available as a serviceable part. Therefore it is no longer necessary to replace the complete transmission assembly for concerns related to the transmission selector shaft detents (transmission stuck in gear).
Should it become necessary to replace the transmission selector shaft detents, refer to the new procedure detailed in Global Technical Reference GTR Workshop Manual, section 308-03.
Parts Required:
Transmission Detent Kit LR017294 1
Labour Time:
Selector Shaft Detents – renew 37.16.75 4.9 hours Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #49964 28th Dec 2010 11:51am
dgardel
Italy
P019v4_EX - Park Brake Oil Contamination
Q068v5_ROW - Engine Lacks Power and MIL Light On - Service Action
Q055 ROW - SERVICE ACTION ‘A’ Frame Suspension Arm
Q054v2 ROW - Brake Pipe Contact with Heat Shield - Defender 2007 - 2008
Q049v4 ROW - Service Action - Engine Oil Pan Damage - Export Markets Only
A234v2 - UNDER BONNET HARNESS ROUTING
LTB00177v4 - Brake Vacuum Pump Seal Oil Leak
LTB00146 - Front Brake Pad Knock/Rattle
LTB00078 - Defender - ABS/TC Warning Lamps Illuminated. (Updated to include ABS Modulator Lower-Level Repair)
LD206-002 - Defender - ABS/TC/HDC Warning Lamps Illuminated
LD206-001 - Defender - Introduction of New ABS Overlay Harness
700194 - Transmission Brake Shoe Rattle at 2800/3000 RPM
0015 - REAR ABS SENSOR HARNESS DAMAGE
SSM43699 - Defender Puma Diesel Turbo/ Intercooler hoses
SSM45326 - Defender rear axle breather pipe 07MY onwards
SSM44470 - Defender transmission oil filler plug
SSM44124 - Method change Defender Transfer Box removal/refit
SSM42403 - Defender 110/130 07 MY on Rear Differential Flange availability
SSM41660 - Defender 07MY onwardsTransmission Synchronizer availability
SSM38851 - Defender 07MY Transfer Box Oil Level
SSM34425 - Defender 07 Model Year - Clutch Pedal Bite Point
SSM44530 - Defender Front Wipers Inoperative / Incorrect Parking on screen
SSM42916 - Defender non start condition 2008my onwards
SSM42787 - Auxiliary jack plug damage / sound quality - Defender
SSM41480 - Starter Motor Diagnostics
SSM40308 - Mulitiple Starter Motor Failure
SSM39653 - Defender 07MY onwards Heater Temperature Imbalance (LHD only)
SSM39533 - Updated battery care manual now available in GTR
SSM30861 - Head Lamp / Fog Lamp Discolouration / Distortion
SSM26067 - Aircon Hose Foul Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #49966 28th Dec 2010 12:00pm
Naks
Thanks,
I suppose I'll just get a 1-day subscription to the Topix site and download all the stuff Neutral
Post #49969 28th Dec 2010 12:18pm
dgardel
Italy
You can read the tittle free of charge Whistle
you must pay if you want the contents
this data came from months of "study" (2008-today) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #49971 28th Dec 2010 12:29pm
Grockle
is this list is just on your Def dg Whistle 2.4 90 XS
Post #49972 28th Dec 2010 12:29pm
dgardel
Italy
MY07, MY08, MY09, MY10, and MY11
MYdgardel is a prototype list.................... Mr. Green Mr. Green Mr. Green Mr. Green Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #49973 28th Dec 2010 12:31pm
Naks
I want the contents. So when I go to the stupid stealer and they tell me 'this noise is perfectly normal', I can whip out a printed version of the service bulletins and tell them to stick it. Thumbs Up
Post #49974 28th Dec 2010 12:32pm
mse
Dealers have access to it - just direct them to the technical ref number - nothing else is really important Thumbs Up Mike
Post #49975 28th Dec 2010 12:35pm
MK
IIRC some early 2.4 models showed some problems on the PCM/ECU. Anybody knows about the issue or where was it published? Puma 110" SW
Post #974978 17th Dec 2022 3:18pm
