Home > Maintenance & Modifications > Simple wiring question
Orchard
Maybe I'm being really thick, but having searched numerous threads, I have to ask;
I'm fitting a chubby box (FCX) with 12v charging sockets / USB, have run the wires to under the drivers seat for power.
How do I get behind the fuses to tap into an appropriate live wire, I've undone the 3 bolts holding the fuse board down but can't lift it seemingly due to 100 wires holding it down?
Also any suggestions as to which fuse or wire to use?
Thanks ! 2015 90 XS SW Bowler
1998 TD5 CSW
Post #498848 31st Jan 2016 10:44pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Can you not take power from the back of the cigarette lighter with an inline fuse?
Thinking about it, you probably won't need an inline fuse because the cigarette lighter must be fused already.
I'm sure Matt at FCX will be able to help you with this.
Post #498854 31st Jan 2016 10:53pm
JWL
Why not take a line straight from the battery to the cubby box via a fuse. Put an isolator switch in if you want to turn it all off but it does mean that you can charge via the USB socket independantly of the ignition on or off.
Post #498873 31st Jan 2016 11:18pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
What JWL said. Keep it simple and accessible.
Post #498950 1st Feb 2016 8:50am
Orchard
Thanks all for the tips, KISS is maybe the best solution Thumbs Up
But how do you get to the wires behind the fuses? 2015 90 XS SW Bowler
1998 TD5 CSW
Post #498956 1st Feb 2016 9:04am
JWL
It is a bit of a pain but when the cover is off you can then see some Phillips headed screws at the ends holdin the metal back plate to the bulkhead, undo these and pull forward, it's pretty self explanatory from there on.
Post #499082 1st Feb 2016 1:57pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
I installed a small fusbox in the battery box, I also have a wiring and relays in there to supply the caravan socket.
I then have one permanent live cigarrette socket and a relay uperated USB socket.
I just fed a wire down from the switch console down, there is actually a 5cm wide channel in the middle of the bulkhead that allows you to feed wire down from the bulkhead, then ran behind the fuse panel and unde rthe carpet into the battery box He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #499088 1st Feb 2016 2:14pm
Furball
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I'm with the others, I've taken a supply off the battery using a simple two fuse outlet. I'm going to change to one of these which is a little pricey but worth it - I just need to double check the battery terminals for compatibility. I find yacht chandlers good for this type of stuff as they tend to sell waterproof kit.
http://www.force4.co.uk/blue-sea-blade-bat...q9xGjbwpnk
Post #499128 1st Feb 2016 3:56pm
gilarion
Half that price at Mud Stuff
http://www.mudstuff.co.uk/blue-sea-fuse-block.html For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #499171 1st Feb 2016 5:49pm
Happyoldgit
An auxiliary fusebox mounted in the battery box and few direct from the battery is a good idea and leaves open the option of connecting other permanently live accessories in the future.
For a one off low draw supply - piggy backs are available that plug into and take a feed off an existing fuse slot in vehicle fuseboxes are available. The idea being that you unplug a standard fuse of your choice, plug in the piggy back which has slots for the original fuse plus an independently fused wire tail from which you can take the feed for the low draw accessory. Steve.
http://forums.lr4x4.com
Post #499175 1st Feb 2016 6:01pm
Orchard
All who have replied - thanks for the generous advice, I think I'm going to put in a secondary/aux fuse box in the battery box, so I can cope with other accessories as they inevitably will happen.
Cheers Bow down 2015 90 XS SW Bowler
1998 TD5 CSW
Post #499263 1st Feb 2016 8:30pm
