Home > For Sale & Wanted > [For Sale] 225/70 15 bridgstone set, Compressor, door lock
Rsmont92
Clearing out my shed for some new toys Whistle
T-Max Compressor, brand new in box. £55 posted
Van vault door lock. all bolts and 2 keys £25 posted
Neilson generator. New but marks from storage. Frame dented on the bottom. £130 can deliver local
Silverline mechanics creeper new £17 posted
Set of 4 Brand new 225/70 15 Bridgstone Dueler H/T tyres £280 posted! Would swap for new 16s
Post #497088 27th Jan 2016 6:32pm
Defender Singh
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Axel stands and creeper
Hi I'll take the axel stands and the creeper thanks
Post #497100 27th Jan 2016 7:06pm
Davidej
United Kingdom 1996 Defender 110 300 Tdi SW Alveston Red
Interested in compressor if you can confirm model no as think they do a couple of versions
Post #497147 27th Jan 2016 8:38pm
Rsmont92
BA2641
Quote:
The T-Max 12 volt air compressor is a heavy duty, portable air compressor, capable of inflating large tyres quickly. Will easily pump an average 4x4 tyre from 15psi to 32psi in 1.5 minutes!
Dont compare with the cheap plastic bodied pumps. These all-metal pumps are far superior and will last for years!
Comes complete with coiled yellow air hose and pressure gauge with a solid brass snap-on fitting to the compressor and secure screw-on fitting on the tyre valve fitting. Has a built-in tyre deflation valve feature. Comes with 3 nozzle adaptors for inflating air beds and inflatables. Heavy duty 2.4 metre power cord with battery clamps and in-line 30 amp fuse. Can be permanently mounted and hard wired if required. Supplied in handy canvas storage/carry bag.
Specifications:
Max Air Flow: 72 litres p/minute, 50LPM @ 30PSI
Max Voltage: 13.8volt
Max Amp Draw: 30A
Max Working Pressure: 150 PSI
Max Restart Pressure: 200 PSI
Max Ambient Temperature: 60°C
Min Ambient Temperature: -40°C
Max Duty Cycle Time: 40 mins @ 30 PSI @ 22°C
Post #497190 27th Jan 2016 9:46pm
Davidej
ok thanks. I will pass on this compressor.
Post #497354 28th Jan 2016 11:07am
Defender Singh
Hi can you confirm that you have received payment of £47 for the axel stands and creeper thanks
Post #497495 28th Jan 2016 5:58pm
Rsmont92
Yes payment recieved, sent off today, should be with you tomorrow
Post #497536 28th Jan 2016 7:28pm
Rsmont92
tyres added
Post #498237 30th Jan 2016 12:21pm
