Home > Td5 > Slickshift
Page 3 of 4 <1234>
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
This sounds tempting but will it improve the change from 1rst to 2nd on a cold TD5??
Also, what are the exact benefits Confused
Post #496711 26th Jan 2016 5:37pm
Tommo
Post #496713 26th Jan 2016 5:37pm
Tommo
Oooops..double post Embarassed
Post #496714 26th Jan 2016 5:38pm
Green Machine
No, it won't improve the poor synchro from 1st to 2nd. That is a notorious feature of the R380 and they all do it (to some degree). The Slickshift will reduce the throw of the gear lever in making gear selections, but that's all. It doesn't mechanically change anything within the gearbox, just the relationship between the gear lever and selector. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #496858 26th Jan 2016 10:12pm
geobloke
The only thing that can help that notchiness is decent oil and regular oil changes. The diff lock evolution oil (which I am fairly sure is just Fuchs 75w/80) does a good job of removing most of the notchiness. Some folks swear by additives like molyslip a do alike. OpieOils pointed me in the direction of Redline oils earlier this week as an alternative, reviews seem very good.
Slick shift going in this weekend...
Post #496917 27th Jan 2016 7:57am
miker
Even my just fitted Ashcroft refurb is a bit notchy 1st-2nd when cold!
Post #496924 27th Jan 2016 8:31am
landybear
United Kingdom 2003 Defender 90 Td5 HT Belize Green
After ordering the SlickShift from Paddocks it arrived quickly but unfortunately was rusty. Requested to send it back and then advised that the entire stock was showing signs of corrosion, so I've paid but nothing to show for it currently. After speaking to the manufacturers via Facebook (who responded within a few minutes), it appears that this must have been early stock (as new is now grease paper wrapped) and they were then also going to contact Paddocks. Fingers crossed it will all be sorted soon and I can get on with fitting it.
 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous)
Disco 2 Landmark 2004, 2001, 2002 (Previous)
Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous)
Defender 110 300tdi 1993 (Previous)
Range Rover Vogue 4.6 - 2001 (Previous)
Freelanders TD4 (2001 3 door & 2002 5 door) Previous
90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others
Post #503313 10th Feb 2016 10:10pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Have you fitted yours yet Grafty? Any feedback?
Post #503567 11th Feb 2016 5:50pm
grafty99
Not fitted yet, still waiting for my defender to be finished. Next week or two hopefully! Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #503578 11th Feb 2016 6:25pm
Lambley
Any feedback yet Grafty? Whistle
Post #510216 3rd Mar 2016 7:51am
grafty99
Unfortunately not, STILL defender-less Big Cry 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #511082 5th Mar 2016 5:16pm
dunc
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
Just came across this thread - interesting!
Sorry if this has been asked before - will this mod fit 2015-16 Defender (I know this is a TD5 thread)? I see reference to "LT77 & R380 ONLY". Being new here I don't know what the latest Defender has. If this doesn't fit, is there a slickshift for the latest Defender?
Post #511111 5th Mar 2016 6:24pm
yoz0807
United Kingdom 1999 Defender 90 Td5 HT Oslo Blue
Got mine today and fitted it this afternoon Very Happy
Not had time to go out and test it yet but even just sat in the back yard the gear change feels phenomenally better with a shorter throw and much more precise. Will let you know how it is on the road when I have driven it (tomorrow).
Thing is....
When I removed the top selector tunnel there was an amount of red oil around the selector.
Should this be there?
Or have I got a leaky seal?
Post #511117 5th Mar 2016 6:42pm
Lambley
Did you get to drive it today Yoz?
Post #511420 6th Mar 2016 7:04pm
yoz0807
Yep..
What a difference.!!!
I am sure that I could have made some improvement by resetting the tension springs on the standard shifter.
However, the throw between gears is noticeably shorter.
I moved the gear lever round a notch on the spline throwing it a little closer to the driver.
The gear change is much crisper now, more definite and not like stirring soup.
The wife is only a tiddler. 5 foot and half an inch. Don't forget the half an inch.
She is over the moon with these changes as she was really struggling to reach the gear lever and hit the right gear.
Good mod
Post #511772 7th Mar 2016 8:34pm
Page 3 of 4 <1234>
