![]() | Home > Maintenance & Modifications > Power for rear Scenelight.. |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
I am a self confessed 'luddite' when it comes to electrical 'stuff'!!
Having successfully fitted my LED 'Scenelight' to the rear of my Defender, I am trying to find a power source, to connect the positive and negative Scenelight wires to! I will route the power through a seperate switch in the rear load area! I need a permanent live to run the light with the ignition off. Another option is the rear 'cabin light'?? I have read up here on the infamous 'purple power' wire but am not sure as the one visible has a green strip on it..? Also, is the black wire negative? Photo attached showing all the wires behind the rear speaker panel! Many thanks, Pete. ![]() ![]() Click image to enlarge YOLO... You Only Live Once... |
Pete, think you may find the answer for 2012 onward model years in below thread. Read especially what DiscoStu has to say about where to find the purple permanent live.
Eric http://www.defender2.net/forum/topic20319-45.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks for the replies!
![]() WHAT a day! Now I again know why I did not become an auto electrician! Got it sorted today. Went to the afore mentioned auto electrician and he suggested that the purple wire to the rear demister was a 'switched' live. He suggested as the SceneLight is LED with a low current draw, to use the cabin light as the source! I had already take off the rear side trims and the rear roof trim, but not the headlining. How to feed a wire from the rear cabin light backwards ![]() A few more hours later, all done! Switch installed and a nice Scenelight all working! Well chuffed! Pics will follow, promise! ![]() |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1179 ![]() ![]() ![]() |
Hi Yolo,
So you have wired it to the interior light for power with a switch inside to turn power on? Good idea. I was going to wire mine to the reverse light power with a switch, you way seems a bit less labour intensive. ![]() G My confidence has been writing cheques that my abilities can't cash for years. |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
You do know the interior light is switched by the AS10 Alarm ECU! http://www.toine-hendriks.nl/hobbies/AS10.h3.jpg If you draw to much current it can cause damage to it! or start other electrical gremlins! Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
OMG!
No I did not know that ![]() I have wired a Scenelight... http://www.labcraft.co.uk/product/scenelite-si7/ Can you advise if you think this is too much current to draw? Cheers, Pete. ![]() |
Ranger Member Since: 17 Nov 2011 Location: United Kingdom Posts: 75 ![]() ![]() ![]() |
I had the same idea but decided to run all ancillaries from a separate fused feed. I used the Mudstuff UK Bluesea fusebox rather than start cutting into the vehicle wiring. Each ancillary is separately fused and switched, with the battery protected by a magefuse. It also makes tracking down any faults easier.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Sort of yes... the interior light feed has a permanent live (nothing to do with the 10AS and also feeds some other things like the clock), permanent ground (nothing to do with the 10AS) and switched ground (everything to do with the 10AS and should be avoided for this sort of thing). I don't know what the current sinking capacity of the 10AS is, but my interior light was using about 700mA (engine off) before I changed it, and in a 110 CSW you could have three, so I'd guess something around 2.5A. I doubt you'll have issues with the permanent wiring to the interior light, it's fused at 10A. The purple (permanent live) is 1.0mm2 cable, the earth starts at 0.5mm2 then grows to 1.0mm2, I guess they're assuming you're not going to have all the interior lights on manually at once or something. Although actually 0.5mm2 would be OK for 3A. If I've read the diagram correctly, the fuse in question also does the diagnostics socket, something on the dash (although those two are listed as 5A instead of 10. It's definitely 10), the clock and permanent to the CD player. |
As you can see, the Scenelite draws 1.25A.
I have also replaced both standard interior Festoon bulbs with LED versions... much lower current drain. So, I think I will be ok on this even if they are all on? ... as you say it's fused at 10 Amps. Question, given your comment about the cable width being 1.0mm reducing to .05mm, I have used twin core 2mm for the feed... is that ok? Or should I re-do this with smaller wire? Time to learn some proper stuff about auto electrics I think! ![]() Many thanks! YOLO... You Only Live Once... |
The bigger the better
![]() Big cable means lower resistance so you waste less energy heating the cable up and more gets to the light. The disadvantage is it costs and weights more. Something like the Labcraft Scenelight (and you can tell by the fact it's rated for something like 9-32V) is regulated, meaning it will be just as bright at 30V as it is at 10V. The flip side of that is that as the voltage drops, in order to keep taking the same amount of power the current goes up. P=IV, that is Power=Current*Voltage Also V=IR, that is Voltage=Current*Resistance. Rearrange them, and P=I*I*R, so in order to get twice the power you need four times the current, or if you double the current you get four times the cable losses. |
Thanks!
I can now replace all the trims knowing they won't have to come off again soon! ![]() |
